Page 3 of 9 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 86
  1. #21
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,103
    It would help if you can post a drawing with just the two circles in it.
  2. #22
    Full Member
    AutoCAD 2011
    Oct 2012
    36
    Why aren't you snapping from center on one circle to center on the second circle? I don't understand why you are using "nearest" on the second circle. "Nearest" to what?
    If i want the center of a circle to be spot on the Circumference of the other circle, and your answer is not a solution.
  3. #23
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,103
    What is your VIEWRES set to?
  4. #24
    Full Member
    AutoCAD 2011
    Oct 2012
    36
    Quote Originally Posted by eldon View Post
    Here you go, this is right before i click to place, as you see it wants to put it far away from the Circumference.
  5. #25
    Full Member
    AutoCAD 2011
    Oct 2012
    36
    My VIEWRES is set to 1000, i have no clue what that is Btw...
  6. #26
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Set it to 10000 and please post a dwg.
    Drafting is a breeze.
  7. #27
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,103
    You can see in the picture (which is not the same as a drawing file) that the circle is tessellated. It is a viewing problem on your set up. Therefore I asked for the drawing file to see if it exhibited the same problem on someone else's set up.
  8. #28
    Full Member
    AutoCAD 2011
    Oct 2012
    36
    Quote Originally Posted by RobDraw View Post
    I am sorry for arguing, but im not very sure my company would like me to upload any files, they are in rome right now so i cant ask them.
    However, the problem seemed to be the Viewres, and the problem is solved.
    I WILL NEVER FORGET THIS!
    TANK YOU!
  9. #29
    Full Member
    AutoCAD 2011
    Oct 2012
    36
    How do i set this thread to solved?
    First time using the forums...
  10. #30
    Full Member
    AutoCAD 2011
    Oct 2012
    36
    The thread is not solved afteral, the viewres only made it less apparent.
    Here is my drawing.
  1. Trim and Intersect inaccurate
    By Gavin Studd in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Oct 2012, 08:20 am
  2. Display Full Path in Title inaccurate - C3D 2011
    By Hardney in forum Civil 3D & LDD
    Last Post: 13th Oct 2010, 12:57 am
  3. Scale and Dimension inaccurate
    By j0ewhite in forum AutoCAD Beginners' Area
    Last Post: 24th Jun 2009, 06:19 pm
  4. inaccurate line definition when trimming or extending
    By Patrick Clark in forum AutoCAD Drawing Management & Output
    Last Post: 15th Oct 2007, 01:40 am
  5. Inaccurate Limits in model space
    By Scott2Finish in forum AutoCAD Beginners' Area
    Last Post: 3rd Sep 2007, 11:25 pm
Tags for this Thread
