Sorry, but I have to ask, is Snap on or off? Lower left, second icon from left or it will say SNAP depending on how it is set.
Hi All, I hope this is in the right area.
I use LT 2012 for some very basic designs on our waterjet, nothing complex at all. It ran fine for a about a year, now all of a sudden it is very choppy when I try to work in it. I can open a file file just fine but as soon as I try to draw something it becomes unworkable. I can "stretch" things fine but trying to draw is driving me mad!
I can not think of anything significant that has changed on my machine other than adding Illustrator CS6.
Here are my machine specs:
Intel Core i5 CPU M480 @ 2.67GHz
RAM 4.oo GB
64 Bit
Windows 7 Ultimate Service Pack 1
Is there any other info needed?
Oh yeah, I have service packs 1 & 2 applied to the AutoCad program.
Thanks,
Mark
"You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
Snap Mode (F9) is OFF, Object Snap and Object Snap Tracking are both on.
When I made the original post there were "Similar Posts" shown below my mine, I am reading through them as I get a chance.
Mark
I found this if it is helpful:
Performance Tuner Results Log
Version: 18.2.0.1
Date of Last Tune: 1/13/2012
Machine Configuration
Processor Speed : 2.7 GHz
RAM : 4013 MB
3D Device
Name : NVIDIA GeForce 310M
Manufacturer : NVIDIA
Chip set : GeForce 310M
Memory : 2216 MB
Driver : 8.5.0005.29055
Your machine contains a 3D Device that is not certified.
As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
Current application driver: Software
Current Effect Status:
Enhanced 3D Performance: Not recommended and off
Smooth display: Not available
Gooch shader: Software emulation in use
Per-pixel lighting: Not available
Full-shadow display: Not available
Texture compression: Not available
Advanced material effects: Not available
Available application drivers and effect support:
Software driver
Effect support:
Enhanced 3D Performance: Not applicable
Smooth display: Not applicable
Gooch shader: Software emulation only
Per-pixel lighting: Not applicable
Full-shadow display: Not applicable
Texture compression: Not applicable
Advanced material effects: Not applicable
Autodesk driver: Not Certified
Effect support:
Enhanced 3D Performance: Available
In what other ways has AutoCAD become unworkable?
Do you receive any error messages?
When did the problem first come to light?
Do you receive drawings from outside sources?
Is the InfoCenter enabled or disabled?
Are you on a network?
Did you change your antivirus program recently? Did you try disabling it temporarily to see if it made any difference?
None noticable.
No
That is hard to answer as I may go weeks between using AutoCad, maybe 2 months ago
No
I don't know what this is
Yes, but my computer is not public
I disabled the antivirius but it didn't help.
I just updated my video driver and it didn't change anything.
So you are working off the network and not off your hard drive right?
How many other people using AutoCAD at your company?
InfoCenter (a.k.a. - the Communications Center) is basically a track mechanism by AutoDesk posing as a feature. To learn how to disable it click on the link below.
http://otb.manusoft.com/2009/03/disa...tocad-2010.htm
Could you better define "choppy"? What command(s) is/are being used that exhibit the behavior? Is it all commands, the draw commands, the modify commands?
I have found that using polar tracking, object snap tracking, and dynamic input all at the same time can result in very choppy cursor movement, when the cursor has a grip on an object 'handle' while in the act of manipulating the end of a line. Whether initially drawing the line or moving one end or the other makes no difference. The tighter I have my polar tracking angle increments, the worse it is.
I guess trying to display the polar vectors with associated position change fields, osnap symbols, and the movement of the object itself is a bit much for my graphics card. Zooming while doing all this makes the thing go ape snot nuts.
I wonder if this is similar to your difficulties.
Yogi Berra: "In theory there is no difference between theory and practice. In practice there is."
While I am on a network the AutoCad program run off my hard drive and nobody else uses it.
I'll look into the Infocenter stuff, thanks!
By choppy I mean that I can open a file (or start a new one) and move around the image fine, but as soon as I began to draw a line for example the on screen cursor lags behind the inputs or mouse movements.
I can "stretch" things without too much choppiness but drawing is a beating.
Let me say again that the program ran fine for several months and began this behaviour in the last month or so.
I appreciate everyones input!
Mark
Are your drawings stored on the network?
The drawings are stored on my HD as well as on the server, it does not seem to make a difference where they come from, same problem.
I disabled the Comm Center and no change................![]()
