What are you looking in fact to achive? To check if a given string (i.e. client name) is present or to retrive the name of client (the third folder from root)?
Hi,
I'm usingto get my current filepath and i would like to get a specific string from it.Code:(setq Cfilepath (getvar 'DWGPREFIX))
Filepath : "L:\\ECHAFAUDAGES (L2)\\CLIENTS\\Name of client\\Project name\\ingénierie\\PlanCad\\"
Thing is i'm not sure what to use since
Name of client never has the same lenght, and same for project name.
So i can't use substr.
What function should I be looking for ?
Regards,
Mircea
AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
Look into:
vl-string-search
vl-string-position
wcmatch
String to List
Lee Mac Programming
Just another Swamper
Well Client name will always be present. I just want to retrieve the project name to print it in a .txt file
Then you may use this function:
Use it like:Code:;;++++++++++++++++++ ;; parser by CAB ;;++++++++++++++++++ (defun sparser (str delim / ptr lst) (while (setq ptr (vl-string-search delim str)) (setq lst (cons (substr str 1 ptr) lst)) (setq str (substr str (+ ptr 2))) ) (reverse (cons str lst)) )
For sure this presume that project name will be always the 4th folder from root.Code:(nth 4 (SPARSER (getvar "DWGPREFIX") "\\"))
Regards,
Mircea
Maybe also .
substr
- When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
