Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie
    AutoCAD 2013
    Oct 2012
    2
    Smile How do you trim unwanted lines in a solid
    Hi, If you have a solid a there are inner lines you want to trim how do you do that in autocad 2013. Panchovia
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,986
    Do you mean edges? Can you post a picture of your case?
    And, by the way, welcome to the Forum!
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    Could those "lines" be left over 2D geometry used to create the 3D model?
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Turn off the solid layer?
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #5
    Forum Newbie
    AutoCAD 2013
    Oct 2012
    2
    Here is a outline of the problem if you have a box and you place a cylinder at each side of the faces when combine it into a solid you should get a round face at each side one of the side the software did it correctly the other there is still has a piece of the cylinder on the bottom how dou you trim this piece.
    Another problem I have is with inventor fusion it keeps popping up jamming the software I used appautoload to turn it off nothing.
    I have 4 gig of mem how gig of mem do you need.
    I think autocad 2013 is full off oops it doesn't recognised certain commands.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    AutoCAD 2013 will work better if you download and install service pack 1.1. Did you?
    In your next post attach a copy of the actual DWG file. Someone here will take a look at it and tell you how to go about solving your problem.
  7. #7
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Quote Originally Posted by Panchovia View Post
    Here is a outline of the problem....
    Instead of an outline - why not post the dwg file?
  8. #8
    Full Member
    AutoCAD 2012
    Oct 2012
    53
    maybe slice tool?
  9. #9
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Specfically what commands? I have not seen this behavior.
  10. #10
    Forum Newbie
    AutoCAD 2010
    Oct 2012
    3
    I think you may need to slice the unnecessary bit off. Not really sure till I see the file though.
  1. Unwanted Lines
    By WERDNA in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Feb 2012, 06:41 pm
  2. unwanted lines
    By david in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Jul 2009, 12:57 pm
  3. unwanted lines
    By david in forum AutoCAD Beginners' Area
    Last Post: 15th May 2009, 04:34 pm
  4. 3D unwanted lines
    By daveyboyd in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Aug 2007, 10:56 am
  5. Unwanted lines
    By pjm2007 in forum AutoCAD Beginners' Area
    Last Post: 20th Mar 2007, 02:24 am
