trilok2047 Posted October 26, 2012 Share Posted October 26, 2012 I am a Student learning AutoCAD. I haven't used x ref till now.. I think it is the right time to learn x ref. So I want from you detail explanation or the relevant site /video tutorials from where I can learn x ref from beginner to advance level... Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 26, 2012 Share Posted October 26, 2012 You can find a tutorial here...http://www.we-r-here.com/cad/tutorials/level_4/4-7.htm about external references (xrefs). Here is a link to another (very brief) tutorial...http://www.2learncad.com/tutorials/xref.html For something more in-depth read Bill Fane's three part article regarding xrefs that appeared in Cadalyst magazine. Part 1...http://www.cadalyst.com/cad/autocad/x-marks-ref-learning-curve-autocad-tutorial-6434 Part 2...http://www.cadalyst.com/cad/autocad/clipping-right-along-with-xrefs-learning-curve-autocad-tutorial-6452 Part 3...http://www.cadalyst.com/cad/autocad/a-stroll-down-xref-path-learning-curve-autocad-tutorial-6463 You can find many video tutorials on line as well with a simple search. Quote Link to comment Share on other sites More sharing options...
Bogbadbob658 Posted October 26, 2012 Share Posted October 26, 2012 There are plenty of tutorials on Youtube. This one's not to bad. http://www.youtube.com/watch?v=-qfAEyZ557I. In a nut shell xref's allow to insert the contents of one model file into another without actually copying the data in. This helps keep the file sizes down. It also means you can use a model file as a base for multiple models so if you update the base model it will automatically update the other models. As an example I use AutoCAD for designing housing estates. I xref the survey into my site model as a base. I would suggest you watch one of the youtube videos then come back with any specific questions. Quote Link to comment Share on other sites More sharing options...
trilok2047 Posted October 27, 2012 Author Share Posted October 27, 2012 thanks remark and Bog........ Quote Link to comment Share on other sites More sharing options...
