Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    AutoCAD 2013
    Nov 2011
    6,049
    Welcome to the forum.
    If I am not mistaken, after you reset it, if you return to check you will find that it is still whatever dimensional system (Metric or Imperial) it was before you reset it.
    Which is why I strongly suggest the use of the -dwgunits command, with your commandline text window expanded.
  2. #12
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,595
    Quote Originally Posted by Dadgad View Post
    I would go with post #10.
    Dadgad - what do you mean when you write "if you return to check you will find that it is still whatever dimensional system it was before you resent it"?
    With nothing drawn in a drawing, going from imperial to metric is nothing more than using Units and picking decimal. Then when you draw, a unit is mm, cm or M, you pick one in your head and continue that way.
    Maybe I am missing something but that is how I do things without any issues.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  3. #13
    AutoCAD 2013
    Nov 2011
    6,049
    Good point, I was mistakenly talking about the DEFAULT SCALE LIST, which is available in OPTIONS, as shown in the image. Should one try to change from Metric to Imperial here, it won't tell you that you can't, implying that you can, but when you use the RESET option the existing template based dimensional unit bias will be preserved.
    By way of curiosity, and with loads of respect ... bordering on awe, have you ever used the -dwgunits command?
  1. Bring Paper Space object through Viewport into Model Space
    By karenreeves in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Nov 2011, 08:58 pm
  2. Acad 2010 - Text size changes in model space behave as if in paper space.
    By Trickinitup in forum AutoCAD Drawing Management & Output
    Last Post: 7th Sep 2011, 03:44 am
  3. 2011 AutoCAD - Setting my LTSCALE in Paper Space as the same it is in Model Space
    By Rage221677 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Dec 2010, 07:31 pm
  4. AcadPViewport2 - Deleting items in model space that aren't seen inside paper space
    By lovemy65stang in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 05:26 am
  5. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
Tags for this Thread
