Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Senior Member
    AutoCAD 2010
    Jul 2011
    222
    Default Looking to use Wcmatch
    Hi,
    I'm making a I beam routine.
    now I would like to use a file with all the specification and make them use it in the routine. Such as this file. Specification.txt
    Code:
    (setq name (getstring T "\nGive name of I Beam : "))
    (setq H
          L
          EA
          ES
          k
          k1
    So I want to set those variable with the one in the .txt file according to the name given.
    Anyone have a suggestion !
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,004
    This looks more like a job for ASSOC:
    Code:
    (setq listProfiles '(("W530 x 85" 535 166 10.3 16.5 35 22)
                         ("W530 x 74" 529 166  9.7 13.6 32 21)))
    (setq listBeam (cdr (assoc name listProfile))
    (if listBeam
     (setq H (nth 0 listBeam)
           L (nth 1 listBeam)
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Senior Member
    AutoCAD 2010
    Jul 2011
    222
    Well can I put it in another file.. since the I beam list is pretty long
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,631
    This is enough ..
    Code:
    (mapcar 'set '(H L EA ES k k1) (list "W530 x 85" 535 166 10.3 16.5 35 22))
    - When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
  5. #5
    Senior Member
    AutoCAD 2010
    Jul 2011
    222
    Well i'm pretty sure they work and all... But i'd like to make it a seperate file since I have like 288 different I beam
    like it i would use :
    Code:
    (setq list (open file "r")
    ... etc
    I know i'm asking alot
    But I want to learn fast more and more
  6. #6
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,631
    That's correct . and use the function read-line to read the line of values with while function to run to the end .
  7. #7
    Senior Member
    AutoCAD 2010
    Jul 2011
    222
    Now I get to this and it's not keeping the variable in memori..
    Code:
    (setq f (open "C:\\Users\\francois.levesque\\Documents\\specification.txt" "r"))
    (setq name "W530 x 74")
    (setq listt
    (while (setq blist (read-line f))
         (if (wcmatch blist (strcat "*"name"*"))
           (princ blist)
    Now, what am I missing.
  8. #8
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,631
    What are you trying to achieve ?
  9. #9
    Senior Member
    AutoCAD 2010
    Jul 2011
    222
    Well keep the line in memorie so i can use them and put each variable in a setq
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,631
    You should step through each line of string and divide it by spaces or characters or what ever you have in your criteria .
    functions may help in this regard .
    Code:
    vl-position
    vl-string-search
    vl-string-position
  1. wcmatch for html special characters
    By David Bethel in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jan 2012, 02:46 pm
  2. wcmatch
    By au-s in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Oct 2010, 04:47 pm
