anp2012 Posted October 30, 2012 Share Posted October 30, 2012 Hi All, In general, we can select the objects first and then run a command. I have a problem with this, autocad wont let this in my PC. If i select objects and run a command, autocad wont take the selection and prompts to select objects. I work on PC in a company connected to server, but the problem is only on my PC. Thanks all for the reply Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 30, 2012 Share Posted October 30, 2012 It sounds like your OPTIONS settings on the SELECTION tab are keeping you from being able to do that. Refer to the image, and I believe that will solve your problem. Quote Link to comment Share on other sites More sharing options...
anp2012 Posted October 30, 2012 Author Share Posted October 30, 2012 It sounds like your OPTIONS settings on the SELECTION tabare keeping you from being able to do that. Refer to the image, and I believe that will solve your problem. Am greatful to you it solved my problem. But why is that selection called NOUN/VERB.....! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 30, 2012 Share Posted October 30, 2012 That is the PICKFIRST system variable, and you want it set to 1, like most users. If you look at this description from the SYSVDLG dialog box, it will probably make more sense to you. If you have never explored it, the SYSVDLG command opens a whole new world, of easy access to the various optional settings used by the software, to define how commands work. If you want to experiment with different system variable settings, make sure you write down each one you change, lest you want to undo something, and can't recall what you changed. Quote Link to comment Share on other sites More sharing options...
MSasu Posted October 30, 2012 Share Posted October 30, 2012 But why is that selection called NOUN/VERB.....! I would guess that it is a grammar analogy. See the "verb" as the edit command, respectively the affected items as the "noun". Quote Link to comment Share on other sites More sharing options...
danellis Posted October 30, 2012 Share Posted October 30, 2012 Given what the words mean (noun = name, verb=action) I'd guess that noun-verb is supposed to indicate that you select an object rather then select an action, rather than the more traditional (in AutoCAD) select the action then the object. dJE Quote Link to comment Share on other sites More sharing options...
danellis Posted October 30, 2012 Share Posted October 30, 2012 Looks like MSasu beat me to the punch. And had the benefit of writing in English! Think it might be coffee time. dJE Quote Link to comment Share on other sites More sharing options...
