Results 1 to 4 of 4
Thread: Colors
    Full Member hcostanzo's Avatar
    hcostanzo's Computer Details
    Windows 7
    Civil
    hcostanzo's Discipline Details
    Civil
    worked in the Structural field for 5.5 years, now learning the ins and outs of civil work
    Civil 3D 2013
    Sep 2012
    Colorado, USA
    25
    Default Colors
    I have a basic question
    A co-worker recently said something about the numbers of colors having to do with the precentage of fade in the color. I hadn't heard anything about this (self taught though so not surprising) and I did a quick help search and google search but couldn't find anything explaining this in detail. I thought that this aspect was only controlled by the ctb file we used. Is there more to the makeup of the colors?
    Any help is much appreciated.
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,483
    That's not really accurate. The "colors" are simply a palette of available color options to choose from, but you are correct that it's the CTB that has the final settings in how the color is displayed or plotted. All the colors can be set by the CTB file to display or plot as "Black" which completely override the colors. Obviously by just looking at the color palette, you can see the transitional fades of colors but that doesn't necessarily have anything to do with the percentage of fade in the color when the design is outputted. Unless, of course, the CTB file was made to represent the color as the percentage of fade in the color.
    Hope that clears it up. I've never been good at explaining things.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Windows 7
    Civil
    Civil
    Civil 3D 2013
    Sep 2012
    Colorado, USA
    25
    That makes a lot of sense, I'll have to look into how the ctb file is set up. I think that must be what he was talking about.
    Thank you!
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,986
    Quote Originally Posted by hcostanzo View Post
    There is some rightness in this statement; if you will check the indexed colors palette will notify that the main body of colors is divided in two groups of 24 series, one group numbered x0 to x8 (even indexes), respectively one x1 to x9 (odd indexes) - where x take value from 1 to 24. In each set the color enhance with the index. Also, the odd sets are lighter then their even pair. So, you can say that a color with index x0 or x1 is a fade one, while x8 or x9 is his intense correspondent.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  1. colors
    By KRYZZ in forum AutoCAD Drawing Management & Output
    Last Post: 8th Apr 2012, 08:11 am
  2. Change pastel colors to alternative colors by layer & elements & blocks
    By deucer in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jul 2010, 06:13 pm
  3. Colors
    By harley558 in forum Autodesk Inventor
    Last Post: 20th Apr 2010, 08:07 pm
  4. STB and colors
    By MarkytheSparky in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th May 2008, 09:11 pm
  5. layer colors
    By bluemole in forum AutoCAD Beginners' Area
    Last Post: 2nd Aug 2006, 05:46 pm
