Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    Junior Member
    Inventor 2011
    Oct 2012
    13
    One last problem. I cannot use this on o.125" plate with any thread size. I get an error message
    Modelization Error
    Failed to create CoilFeature... Try with a bigger Pitch Offset value
    OK Cancel
  2. #12
    Senior Member
    Bishop's Computer Details
    Windows 7 Enterprise
    Dell Precision T1600
    Xeon E3-1280
    16 GB
    Quadro 600 1024 MB
    Seagate 250GB - ST3250312AS
    Western Digital 1024 GB - External
    2x Dell P2211H @ 1920 x 1080
    Multi-disciplinary
    Bishop's Discipline Details
    CAD Design, Manufacturing
    Multi-disciplinary
    Inventor 2013
    Nov 2009
    Democratic People's Republic of Kalifornia
    406
    Attach your part here, we'll have a look at it.
  3. #13
    Junior Member
    Inventor 2011
    Oct 2012
    13
    Done. I was able to use the tool on a part with only 0.100" thickness.
    Thanks,
    Victor
  4. #14
    Senior Member
    Xeon E3-1280
    16 GB
    Quadro 600 1024 MB
    Multi-disciplinary
    Multi-disciplinary
    Inventor 2013
    Nov 2009
    406
    Huh. That's ... interesting.
    I think it's got something to do with the sketch that's getting used as a template for the coil feature, but I'm not positive.
  5. #15
    Junior Member
    Inventor 2011
    Oct 2012
    13
    I was just told that the plugin does not work with sheet metal parts. Does not make sense.
  6. #16
    Senior Member
    Xeon E3-1280
    16 GB
    Quadro 600 1024 MB
    Multi-disciplinary
    Multi-disciplinary
    Inventor 2013
    Nov 2009
    406
    Looks to be the case.
    As soon as I turned it back into a standard part, Thread Modeler worked out just fine.
    That part though, it doesn't really need to use any of Inventor's sheet metal tools, so there's no need to make it as a sheet metal part.
  7. #17
    Junior Member
    Inventor 2011
    Oct 2012
    13
    Agree on that part. I do have a sheet metal part that requires bening that has holes. Does not make sense.
  8. #18
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    You can always convert a standard part to sheet metal (or the other way around).
  9. #19
    Senior Member
    Xeon E3-1280
    16 GB
    Quadro 600 1024 MB
    Multi-disciplinary
    Multi-disciplinary
    Inventor 2013
    Nov 2009
    406
    Once you've used Thread Modeler you can't convert back to sheet metal, JD. Features are incompatible, unfortunately. Although ... this brings up another point: when you convert to .IGS, you're going to be losing all the tooling stuff that Inventor builds into the sheet metal parts. Your flat pattern, bend angles, etc., aren't going to come through. You'll just get a model, so you're really not giving away anything to just make the sheet metal part, then convert to a standard part and do the threads afterwards.
  10. #20
    Junior Member
    Inventor 2011
    Oct 2012
    13
    Thanks. I made a backup then converted and threaded. 5 years later ready to send the design for production pricing.
  1. how to export from 3D MAX to IGES and into Inventor?
    By ArtEm10 in forum 3D Modelling
    Last Post: 1st Dec 2011, 05:48 pm
  2. how to export from 3D MAX to IGES and into Inventor?
    By ArtEm10 in forum Autodesk Inventor
    Last Post: 1st Dec 2011, 02:53 pm
  3. Export to IGES in Version 12 Trial not working
    By Gearz Drums in forum AutoCAD Beginners' Area
    Last Post: 14th Nov 2011, 12:39 am
  4. AutoCAD 2011 Subscription Advantage Pack - IGES Import/Export
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 22nd Oct 2010, 02:50 pm
  5. Replies: 0
    Last Post: 30th Sep 2010, 01:20 pm
Tags for this Thread
