Results 1 to 10 of 10
    Full Member
    not specified
    Jun 2005
    Edinburgh, UK
    47
    Default Pagesetup in LT2005
    Right... after 3 years languishing in the cupboard, the office I work in finally decides to install the LT2005 they have, an upgrade from LT2002.
    A couple of days on it and I'm getting more and more annoyed, but that's for another day.
    My main annoyance now is how any and all pagesetup that I do, whether on the pagesetup manager or the plot wizard doesn't get saved and I need to set it again and again. It's so stupid that if I were to set up a plot, preview it to see if it's alright, as soon as I get out of the preview the whole thing's reverted back to the default settings (ie: the wee epson printer on A4).
    Does anyone have any ideas? It's driving me nuts!
    ...funny how I didn't see that one coming...
    Full Member Gar's Avatar
    AutoCAD 2007
    May 2006
    Stokesdale, NC
    71
    Are you using a common template?
    If so try opening the template, make the changes, then save the template so as to overwrite the older template... that should make the changes stay....
    Hope that helps....
    Full Member
    not specified
    Jun 2005
    Edinburgh, UK
    47
    No. This is on drawings that were set up using LT2002, so I'm trying to print out old drawings.
    The strangest thing is that it can't even hold a print setting after it's been previewed.
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,584
    follow these steps AFTER setting up your drawing exactly how you want it, plotstyles/paper settings/units/layers.... etc (im sure you get the idea lol)
    File > Save As > save the file as a template (*.dwt)
    go to Tools > Options > System, make sure the "Show Startup dialog box" is selected.
    now everytime you start a new drawings, select the template. does this help ya out? ;-)
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  5. #5
    Full Member
    not specified
    Jun 2005
    Edinburgh, UK
    47
    That would work only if I'm starting new drawings. For some reason old drawings that worked fine before now don't. I can't be creating new layouts based on new templates and setting up all my old drawings again..
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,584
    oh okay i see what you're saying.
    can't help ya with that one. someone far above me would have to help ya i'm guessing lol.
  7. #7
    Senior Member
    AutoCAD 2008
    Apr 2005
    Oh! Canada
    179
    Not familiar with LT but in Autocad there is called Plotter Manager that list plotter configuration (PC3).
    If you have created one for your printer, you should have EPSON.PC3
    You can use this configuration all the time for new and old drawings.
    Larry
  8. #8
    Full Member
    not specified
    Jun 2005
    Edinburgh, UK
    47
    There are pc3 files for every printer installed for use with ACAD.
    So far I've been using the system installed printers, of which the OCE A0 plotter is one. That has been fine all the while with LT2002 and I don't see why it should be a problem with LT2005.
    Anyway, tried to use a custom printer setup saved as a pc3 file just to see what happens, and the whole thing crashed!
    Next thing I did then was to uninstall and reinstall the whole thing. Did it help? No. Same thing again.
    Any ideas?
  9. #9
    Senior Member
    AutoCAD 2008
    Apr 2005
    Oh! Canada
    179
    It looks like a printer/plotter driver conflict; check for newest driver for LT2005.
    How about the others PC3 for other printer? Have you try it if it work?
  10. #10
    Full Member
    not specified
    Jun 2005
    Edinburgh, UK
    47
    ..it's the same with all the installed printers. It just reverts back to the default settings (ie: paper size, scale, "what to plot" - window/layout/extents) for whatever printer it is.
