Results 1 to 5 of 5
    Forum Newbie
    2217's Computer Details
    64-bit Windows 7 Home Premium
    Sony VAIO
    Intel(R) Core (TM) i7 CPU Q740
    8 gigs
    Architectural
    2217's Discipline Details
    Student
    Architectural
    Interior Architecture
    3ds Max Design 2012
    Nov 2012
    4
    Wink Z Axis Movement on Gizmo Disabled
    I'm using 3D Max Design. I am unable to move an object on the Z axis of the gizmo. When I attempt to do so, a yellow line follows the path of my drag. I can move an object up and down only if I drag by all 3 axis.
    AutoCAD 2013
    Nov 2011
    6,056
    Welcome to CADTutor.
    Pardon my asking which of the 3D Gizmos you are trying to use for the 3D MOVE?
    I suggest that you set an ISOMETRIC perspective, if you have not already, and try again.
    You might want to turn on ORTHO or POLAR, and your DYNAMIC UCS, in which case
    you won't even need the gizmo in question. Once again use an ISOMETRIC perspective.
    Forum Newbie
    Sony VAIO
    8 gigs
    Architectural
    Student
    Architectural
    3ds Max Design 2012
    Nov 2012
    4
    Quote Originally Posted by Dadgad View Post
    Thanks!
    I'm sorry. I'm using 3d Max Design. -forgot to note that
    Looks like this question would be better suited in the 3D Forum. oops
    AutoCAD 2013
    Nov 2011
    6,056
    I noticed you referenced using 3Ds Max Design in your profile, but I saw you had posted in the Autocad forum, so took a shot.
    You definitely want to post it wherever the people who can help you the most, are most likely to see it, in a timely fashion.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    I have relocated this thread to the 3DS max forum.
  1. Replies: 1
    Last Post: 26th Jan 2012, 11:46 am
  2. XYZ Gizmo problem
    By Raudel Solis in forum 3D Modelling
    Last Post: 2nd Jun 2011, 03:14 am
  3. Gizmo not there.
    By funk in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th May 2010, 12:50 am
  4. where's my gizmo?
    By jasoooon in forum 3D Modelling
    Last Post: 31st Mar 2009, 07:26 am
  5. Error: The UCS X axis and Y axis must be perpendicular
    By Gerardus in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Jan 2006, 01:02 am
