I need help drawing a industrial lifting hook in CAD 2013
sean214
Okay Got it
I have to mark this off on the first test for 3 or 4 students every year. I'm not the best speller myself, but this one you need to know.
  • Replies 28
  • sean214
    11
  • ReMark
    6
  • JD Mather
    5
  • nod684
    2
Posted Images
Some times when we are really under the gun, and I have been going hard from 7:00 a.m. til 4:45 a.m., a couple days in a row, my last drawing of the
extended day might well have 'dementians' . :beer:
If you stay in this field, you might want to learn how to spell dimension (there is no "t", at least not where I live).
If they stay in this field, they will be spelling it "dementia". :?
Edited by SLW210
You definitely have an eye for detail...thanks, will add them
Diameter symbols (Ø) missing on two dimensions.
%%C or Alt 0216 (using numerical keypad)
or select from Symbols.
Disable the Lineweight option when you do a screen capture it makes the image difficult to read.
Not sure I agree with the way you have called out the arcs (re: R6).
For future reference, dimension lines can be broken in AutoCAD 2012 using the DIMBREAK command.
