Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 67
    Full Member
    DashaB's Computer Details
    Windows 7 Pro 64 bit
    Dell Precision Work Station T7500
    Intel Xeon CPU (E5620 @2.40 GHz, 4 cores)
    ATI FirePro V5800
    (2) Dell P2212H
    AutoCAD 2013
    Nov 2012
    Annapolis, MD, USA
    29
    Default AutoCAD 2013 Increasing File Sizes
    So I have this drawing file that has suddenly been growing larger and larger in size. There has not been enough information added to justify such a large increase:
    Any ideas? (will post more below, my description is too long)
    Full Member
    ATI FirePro V5800
    (2) Dell P2212H
    AutoCAD 2013
    Nov 2012
    Annapolis, MD, USA
    29
    Now here's the kicker. If i take, for example, base7, which is 18.3MB, and i delete EVERYTHING out of it, run every single purge and audit you can think of, get rid of all layers, all styles, everything, the file is then 18.1 MB.
    Someone on the Autodesk forum looked into this file for me and said that there was hidden data in there, but i don't know how to get rid of it.. I have tried wblocking everything out, i tried using new files, i've tried just about everything that I could think of, then i looked stuff up online and tried all those things.
    Nothing will get my filesize down.
    Here is another fun fact:
    This same drawing has different file sizes depending on which version i save it down to:
    2013: 28.3MB
    2010: 28.4MB
    2007: 23.5MB
    2004: 18.5MB
    2000: 190.4MB
    For now, I am sticking with saving down to 2004 for all my drawings, and that is helping a little bit, but I can't shake the feeling that my files are corrupt and that this problem just will not go away on its own.
    Other people in my company also have the same problem. These larger file sizes make it take longer to save (this particular file I am referencing takes 16 seconds to save on average) and basic commands like Copy and Paste can take up to 10 minutes per each (10 minutes to copy, 10 minutes to paste into another file).
    Running audit takes probably 15 minutes, if you're patient enough to wait it out.
    Please please help me figure out how to get rid of my "hidden" junk. Someone said I have AEC and DGN data, but I haven't been able to figure out how to get rid of this data.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    When you do a purge do you use the command line version with the dash in front of it? Do you purge Regapps first?
    Full Member
    ATI FirePro V5800
    (2) Dell P2212H
    AutoCAD 2013
    Nov 2012
    Annapolis, MD, USA
    29
    I do -Purge regapps, then i do -purge all, then just to be safe i run a regular purge and an audit. I also frequently run the OVERKILL command to get rid of duplicate things.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Do you use layer filters?
    Could it be a case of a bloated scalelist?
    Are xrefs attached?
  6. #6
    Full Member
    ATI FirePro V5800
    (2) Dell P2212H
    AutoCAD 2013
    Nov 2012
    Annapolis, MD, USA
    29
    There are no xrefs attached, no layer filters, and the scale list is not a problem.. The line types, test styles, and total layers are all minimal, i've deleted all the hiddne objects, there are no hatches, no points, no wipeouts, no zero entities..
    I've been looking into this problem for about 2 weeks now and the only help I've gotten from the Autodesk forums is that there might be AEC objects or DGN data in my file. If it's in the file, I don't know where it is and how to get rid of it.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    And where did these AEC objects and DGN data originate from? Are you sharing your drawings with others who then return them to you with information they have added?
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    From the website of IMAGINiT Technologies Blog Support.
    How to remove the AEC proxy intelligence from your drawing file
    Are you are having trouble viewing an AEC objects because they were added to the drawing in a different version/platform of the Autodesk software here is what you can do to remove that AEC proxy intelligence so you can view the drawing file with all its objects.
    There are two methods to do this:
    1) In the program that created it (like Architecture), use the Export To AutoCAD command to save the drawing for others to view. This is the recommended method.
    2) Within AutoCAD, Enter EXPORTTOAUTOCAD (for 2009 and later version) at the command line or AECTOACAD (for Autodesk software 2010 and newer.)
    This will convert your drawing to a basic AutoCAD drawing by exploding the AEC objects
    Note: this explodes those objects so they will become AutoCAD Lines/Arc/Circles/etc. In doing this they will lose their smart properties when brought back into Architecture.
  9. #9
    Full Member
    ATI FirePro V5800
    (2) Dell P2212H
    AutoCAD 2013
    Nov 2012
    Annapolis, MD, USA
    29
    Here is how we usually work:
    We receive plans from an architect. We rename the file JobName_base1 and we take out everything we do not need, clean up the drawing, purge all the extra stuff and leave only basic structure (walls, columns, gridlines, etc). I think the AEC objects must have come from them. But it seems like in the previous versions of AutoCAD, when we set up these files, all those secret AEC objects would get deleted and the file size was never a problem, even for this same project. We never kept the AEC objects if there were any, we would explode them and purge out. In the file i am talking about specifically, none show up as AEC objects.
    I have tried asking the architect to do the EXPORTTOAUTOCAD command on their files before sending them to us to set up, but they pretty much blew me off. I am trying it on my problem file right now, but it's still processing haha.. Will let you know when it's done if it helped any or not.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    You may want to also read about importing Microstation DGN files into DWG files and consult with the person or persons who are providing you with drawings in this format. Tell them what you are experiencing and ask them to do what they can to minimize the file ballooning you are experiencing.
    http://exchange.autodesk.com/autocad...94df1-7fa9.htm
  1. New template file (dwt) opens in model space autocad 2013 !!!!
    By darren bagga in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2012, 04:48 pm
  2. Purge & Save Increasing file size
    By CadiCad in forum AutoCAD General
    Last Post: 11th Dec 2008, 05:29 pm
  3. file size keep on increasing
    By shinymathew in forum AutoCAD Beginners' Area
    Last Post: 7th Jun 2007, 04:54 am
  4. MORE help with file sizes and AEC
    By Teeds in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2006, 11:21 am
  5. file sizes
    By ciaran in forum AutoCAD Drawing Management & Output
    Last Post: 10th Aug 2004, 12:50 pm
