Page 7 of 7 FirstFirst ... 5 6 7
Results 61 to 67 of 67
  1. #61
    Full Member
    DashaB's Computer Details
    Windows 7 Pro 64 bit
    Dell Precision Work Station T7500
    Intel Xeon CPU (E5620 @2.40 GHz, 4 cores)
    ATI FirePro V5800
    (2) Dell P2212H
    AutoCAD 2013
    Nov 2012
    Annapolis, MD, USA
    29
    No, we've been saving back to 2004 only because of the weird file size issues when saving to anything else. Saving back to 2000 blows up the file size to around 1gig every time haha. The copy and paste issue, I really don't know why it has been a problem lately. But i did the DXF thing on our working file, and tested it and the functionality remains and the copy and paste issue is solved, so that's my solution to the rest of the company. I think somewhere along the lines, something got messed up in the files, probably because of these baseplans. Something about the way 2013 saves or processes something, i guess?
    Oh well, it works now, that's all I'm worried about. I had nightmares all last night that i was trying to fix this...
  2. #62
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Well you should sleep like a baby tonight then.
  3. #63
    AutoCAD 2013
    Nov 2011
    6,056
    Remark to the virtual rescue.
  4. #64
    Forum Newbie
    AutoCAD LT 2017
    May 2013
    4
    We are having a similar problem, which I have just posted in the General AutoCAD forum. Did you ever get an answer that worked?
  5. #65
    Full Member
    ATI FirePro V5800
    (2) Dell P2212H
    AutoCAD 2013
    Nov 2012
    Annapolis, MD, USA
    29
    Quote Originally Posted by ArchiTex View Post
    Currently our protocol for larger file sizes is to DFXOUT/IN on the file, twice. If you do it once it doesnt quite help all the way.
    So, first off, do a -purge (different from regular purge because it offers a bit more in the options). Type in R (for regapps), then enter, and N for no. This will remove registered applications and should not affect your content in any way. We've had drawings with over 100 of these suckers in there, and getting those out helps with the speed of the drawing.
    Then, in your working file that is a large size, type DXFOUT, save to a location of your choice. Close the file. In a blank file, type DXFIN and select the DXF file you just created. It helps at this point to run an audit, as for me it finds all sorts of errors in the file that it would not normally find. Saveas and overwrite your original drawing. Repeat procedure one more time.
    Not sure why you need to do it twice, but, for example, if my file is 8MB, one DXFOUT/IN reduces it to about 6 MB. The second takes it down to under 1MB.
    If you need further help on this topic, send me a PM and I can e-mail you the set of instructions I forwarded to my team here.
    Thanks!
  6. #66
    Full Member
    AutoCAD 2009
    Mar 2013
    27
    Default Autocad 2013 Increasing files sizes
    I had the same problem but by big drawings dxfout is not working. I found a oder way by deleting all AEC object by using this Lisp:
    Name of Lisp :removeAEC
    (defun gc:GetDictEntries (dict / result)
    (and (= (type dict) 'ENAME) (setq dict (entget dict)))
    (while
    (setq dict (vl-member-if (function (lambda (x) (= (car x) 3))) (cdr dict)))
    (setq result (cons (cons (cdar dict) (cdadr dict)) result))
    (reverse result)
    ;; delete all AEC*
    (defun c:removeAEC ()
    (foreach dict (gc:GetDictEntries (namedobjdict))
    (if (wcmatch (car dict) "*AEC*")
    (foreach entry (gc:GetDictEntries (cdr dict))
    (entdel (cdr entry))
    (entdel (cdr dict))
    );fin if
    );fin defun
  7. #67
    Forum Newbie
    AutoCAD 2013
    Jan 2013
    1
    I know this post is a bit old, however, both topics discussed here (large file size and the inability to copy/paste) are symptoms of the same underlying issue, hidden DGN linestyles. You will want to make sure that every workstation is patched with Autodesk's DGN Hotfix which was released in August 2013.
    I've blogged about the cause of the issue as well as some ways to automate the process in my blog titled AUTOCAD LARGE FILE SIZE PROBLEM. If anyone has any additional questions, let me know.
  1. New template file (dwt) opens in model space autocad 2013 !!!!
    By darren bagga in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2012, 04:48 pm
  2. Purge & Save Increasing file size
    By CadiCad in forum AutoCAD General
    Last Post: 11th Dec 2008, 05:29 pm
  3. file size keep on increasing
    By shinymathew in forum AutoCAD Beginners' Area
    Last Post: 7th Jun 2007, 04:54 am
  4. MORE help with file sizes and AEC
    By Teeds in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2006, 11:21 am
  5. file sizes
    By ciaran in forum AutoCAD Drawing Management & Output
    Last Post: 10th Aug 2004, 12:50 pm
