Results 1 to 3 of 3
    Full Member 19cruthik68's Avatar
    Electro/Mech
    19cruthik68's Discipline Details
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    Default measurement help
    No autocad installed on this unit, I reformat it, the reason why i made this simple question on jpeg file attached below through MS Paint.
    Assume that boxes are MANHOLES and it is a perfect square,
    from the centerpoint of manhole1 up to the centerpoint of manhole 5, I want to know the (exact or not totally exact) measurement/distance in just one click,.
    Other way than using dimlinear(DLI) and or dimalign(DAL). because if i will use DLI/DAL command, it will take more than 30 minutes to get the measurements of those. I mean for example the measurement that they want to know are very long with curves or with etc etc. so is there another way to compute the total measurements of this scenario?
    and so I did.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    You can download a lisp routine like totlen.lsp, once loaded and started you pick each of the blue lines and hit enter.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Junior Member TigerByTheTail's Avatar
    AutoCAD LT 2010
    Aug 2009
    Eastern Kansas, USA
    23
    Do the lines meet at the center if your manholes? Are you drawing in 1:1 in model space? I'm doing fiber optic cable routes. My cable lines break at each manhole. I can select any cable line and check the properties window for length.
  1. how to know what unit of measurement I'm using?
    By 13tildawn in forum AutoCAD Beginners' Area
    Last Post: 13th Sep 2013, 03:18 am
  2. Scale and measurement
    By Johnny Henrick in forum AutoCAD Beginners' Area
    Last Post: 12th Apr 2011, 09:49 pm
  3. Productivity measurement
    By snowonwinterhills in forum CAD Management
    Last Post: 9th Feb 2011, 06:25 pm
  4. Angle Measurement
    By Dipali in forum AutoCAD General
    Last Post: 16th Oct 2008, 01:14 pm
  5. Hatch Measurement
    By sendoor in forum AutoCAD Beginners' Area
    Last Post: 9th Dec 2007, 04:57 pm
Tags for this Thread
