Find & Replace in current layout only
clint0577
I have 2 things I'm trying to accomplish here. I need to find the the exact text to replace and only in the current layout. For example. Let's say I need to find "Date" but on the same layout I have "date", "Date" and "Date:". So it needs to be case sensitive also. I was using this but it's not case sensitive and also replaces "date" and "Date:" in all layouts. I just need "Date" in the current layout.
;Find And Replace
(defun C:FAR ()
(setq OldTxt (getstring T "\nEnter the old text: ")
	  NewTxt (getstring T "\nEnter the new text: "))
(setq ss (ssget "x" '((0 . "TEXT,MTEXT"))))
(setq i (sslength ss))
(while (not (minusp (setq i (1- i))))
	(setq oText (vlax-ename->vla-object (ssname ss i)))
	(setq Txt (vlax-get-property oText 'TextString))
	(if (vl-string-search OldTxt txt)
			(setq newChg (vl-string-subst NewTxt OldTxt txt))
			(vlax-put-property oText 'TextString newchg)
			(vlax-invoke-method oText 'Update)
Hope that your texts are not Annotative ..
(defun c:test (/ oldTxt NewTxt ss in en)
 (if
   (and (not
          (eq (setq OldTxt (getstring T "\nEnter the old text: ")) "")
        (not
          (eq (setq NewTxt (getstring T "\nEnter the new text: ")) "")
    (if (setq ss (ssget "x"
                        (list '(0 . "TEXT,MTEXT")
                              (cons 1 OldTxt)
                              (cons 410 (getvar 'ctab))
      (repeat (setq in (sslength ss))
        (setq en (entget (ssname ss (setq in (1- in)))))
        (entmod (subst (cons 1 Newtxt) (assoc 1 en) en))
