Rendering background color
tomhamlet
I am currently working in 3d and trying to render my drawing. However, most of my object is black, as is the background of the render window. Is there a way to change the background color?
setup your Desired View...
Type VIEW at the command line, select NEW
then below you can see BACKGROUND in which you can choose from, Default (which is your autocad background), SOLID, Gradient, Image, Sun & Sky
Edited by nod684
