laukejas Posted November 15, 2012 Share Posted November 15, 2012 Hello, I'm attaching a design I'm working on (it's a hull of a sailboat). I'm making that shape through use of meshes (since AutoCAD offers no better option). However, from time to time, I need to check the volume of that hull, and here AutoCAD again has no option for it. It can only tell volume of 3d Solid. And I can't convert mesh to solid. So here's what I do: I take that hull, draw 3d Polylines on top of cross-sections, and then loft them. It should produce 3d Solid (it worked before), and I can check it's volume with MassProp. However, now Loft produces Surface instead of Solid, although Loft option Mode is set to Solid. And I can't convert that surface to 3d solid. What is wrong here? Autocad is 2013 with Service Pack 1. How do I loft these cross-sections to produce 3d Solid? I would appreciate if anyone could help as soon as possible, I'm in a bit of hurry. Thanks in advance! 010.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 15, 2012 Share Posted November 15, 2012 What command did you use? Did you try SURFSCULPT? Quote Link to comment Share on other sites More sharing options...
laukejas Posted November 15, 2012 Author Share Posted November 15, 2012 Loft command. It produces Surface. Tried using SurfSculpt - doesn't convert to Surface. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 15, 2012 Share Posted November 15, 2012 SurfSculpt will create a solid. Quote Link to comment Share on other sites More sharing options...
laukejas Posted November 15, 2012 Author Share Posted November 15, 2012 As I said, it doesn't. It says: "Modeling Operation Error: Operation did not add or remove material. Solid creation failed, no watertight volume detected." Try it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 15, 2012 Share Posted November 15, 2012 Unfortunately I am not at my CAD computer at the moment and won't be for some time therefore I am unable to try it. My last response was my way of correcting what I thought was a mis-understanding on your part (i.e. - you expected SurfSculpt to create a surface). I do not doubt that what you tried failed to produce the desired results. Perhaps someone else can assist you until such time as I have access to my CAD computer. Quote Link to comment Share on other sites More sharing options...
SEANT Posted November 16, 2012 Share Posted November 16, 2012 Some of the cross sections are non-planar. See if this works any better. 010_FlattenedProfiles.dwg Quote Link to comment Share on other sites More sharing options...
laukejas Posted November 16, 2012 Author Share Posted November 16, 2012 Yes, it solved the problem - but what did you mean by non-planar? Quote Link to comment Share on other sites More sharing options...
f700es Posted November 16, 2012 Share Posted November 16, 2012 There was a good video showing the making of a boat with AutoCAD. It was one of the promo videos by AutoDesk showing AutoCAD's new 3D tools. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 16, 2012 Share Posted November 16, 2012 Non-planar means objects do not lie in one plane. Quote Link to comment Share on other sites More sharing options...
laukejas Posted November 16, 2012 Author Share Posted November 16, 2012 Well, I understand, but in which plane? And how did you fix this? And for the future, what if I want to loft 3d polylines which are not in one plane, and still get 3d Solid, not Surface? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 16, 2012 Share Posted November 16, 2012 You can use the following objects and subobjects with LOFT: [ATTACH=CONFIG]38629[/ATTACH] Quote Link to comment Share on other sites More sharing options...
