thorcalder0n Posted November 16, 2012 Share Posted November 16, 2012 Hello everyone! So i've been trying to model this part on Inventor, but it's cost me more than what i expected. It is part of an assembly that i'd like to post soon.Maybe you guys could help me with this. As it is in spanish, both "PASO 2" and "12 giros" stand for Step: 2, and 12 Revs., respectively. All dimensions are in millimeters. Thanks PS: Sorry for my bad english. Quote Link to comment Share on other sites More sharing options...
Lazer Posted November 16, 2012 Share Posted November 16, 2012 I cannot see the picture? Try posting it again;) Quote Link to comment Share on other sites More sharing options...
thorcalder0n Posted November 16, 2012 Author Share Posted November 16, 2012 (edited) Mmm, that's strange... how 'bout now? Edited November 19, 2012 by thorcalder0n Image not visible Quote Link to comment Share on other sites More sharing options...
tomhamlet Posted November 16, 2012 Share Posted November 16, 2012 Hello everyone! So i've been trying to model this part on Inventor, but it's cost me more than what i expected. It is part of an assembly that i'd like to post soon.Maybe you guys could help me with this. As it is in spanish, both "PASO 2" and "12 giros" stand for Step: 2, and 12 Revs., respectively. All dimensions are in millimeters. Thanks PS: Sorry for my bad english. Im not sure I understand what you are asking. Are you trying to be able to produce this spring in a more cost effective way? Quote Link to comment Share on other sites More sharing options...
thorcalder0n Posted November 16, 2012 Author Share Posted November 16, 2012 Im not sure I understand what you are asking. Are you trying to be able to produce this spring in a more cost effective way? Well, i'm trying to make this spring, using different approaches (3d sketch, sweep) but none of them had a good result... Inventor seems to be not very flexible with 3D sketches, but I might be ignoring some useful tool in this case. I'd be great though if you could create this part and tell me how you've done it. Quote Link to comment Share on other sites More sharing options...
Lazer Posted November 16, 2012 Share Posted November 16, 2012 Outch you have been using the wrong method, search this forum on the coil command we have talked about it many times. Basically you sketch a profile and a revolve axis or use a one provided, then select COIL. When in the Coil feature you can set the shape , size and end detail. We have lots of examples on this forum on how to do it. Any probs just post on here. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted November 16, 2012 Share Posted November 16, 2012 Attach your ipt file of what you attempted here. I would Coil surface Sweep Mirror Quote Link to comment Share on other sites More sharing options...
thorcalder0n Posted November 17, 2012 Author Share Posted November 17, 2012 (edited) Attach your ipt file of what you attempted here. I would Coil surface Sweep Mirror I started creating the coil acording to the dimensions, but I stuck trying to make the paths at both ends (those ending in a 3 mm radius). So I chose (and attempted) to do this with a helical curve within the 3D Sketch option (I don't know if it is called "helical curve" since i'm using a spanish version of Inventor)... this was some sore of result: But I couldn't bend the intersection between that straight line and the helical curve, so I thought of making a 3 mm arc tangent to both the straight line and the helical curve, but it still won't follow the expected trajectory, as it is shown in the next part, done by a Catia user: (27).ipt (27.1).ipt Edited November 20, 2012 by thorcalder0n Bad Spelling Quote Link to comment Share on other sites More sharing options...
