Baiksu Posted November 19, 2012 Share Posted November 19, 2012 What does Viewres command do? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 19, 2012 Share Posted November 19, 2012 VIEWRES sets the resolution for objects in the current viewport, which is most noticeable as it applies to the smoothness of arcs and circles, try setting it to 10,000, instead of the default 1000. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 19, 2012 Share Posted November 19, 2012 5,000 will do quite nicely. In my opinion setting it to 10,000 is overkill. Quote Link to comment Share on other sites More sharing options...
f700es Posted November 19, 2012 Share Posted November 19, 2012 Oh man, I set mine in my templates at 15,000. Honestly this command is a holdover back to the old days when you had to turn the resolution down due to lack of performance in pc equipment. Back when you planned your "regens" around your coffee break With today's modern computers there is no need to set this down anymore. Just another dinosaur command/settings along with; limits, blips, regenauto and several more Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 19, 2012 Share Posted November 19, 2012 I thought Viewres was replaced by Whiparc (set to "1")? Quote Link to comment Share on other sites More sharing options...
f700es Posted November 19, 2012 Share Posted November 19, 2012 Whiparc is new to me but viewres is still in 2013. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 19, 2012 Share Posted November 19, 2012 Modern computers should easily handle VIEWRES=20000 and WHIPARC=1, LARGE FILES may benefit from a lower VIEWRES and/or WHIPARC=0. My poor little 32-bit 3GB RAM computer handles files of 30MB with VIEWRES=20000 and WHIPARC=1. VIEWRES is a COMMAND and WHIPARC/WHIPTHREAD are SYStem VARiables. VIEWRES Sets the resolution for objects in the current viewport. Summary The model is regenerated. VIEWRES controls the appearance of circles, arcs, splines, and arced polylines using short vectors. The greater the number of vectors, the smoother the appearance of the circle or arc. For example, if you create a very small circle and then zoom in, it might appear to be a polygon. Using VIEWRES to increase the zoom percentage and regenerate the drawing updates and smooths the circle's appearance. NoteIncreasing the zoom percentage in VIEWRES may increase the time it takes to regenerate the drawing. When a paper space layout is made current for the first time and a default viewport is created in the layout, the viewing resolution for this initial viewport is the same as the viewing resolution for the Model tab viewport. The VIEWRES setting is saved in the drawing. To change the default for new drawings, consider specifying the VIEWRES setting in the template files on which you base your new drawings. WHIPARC Type:IntegerSaved in:RegistryInitial value:0 Controls whether the display of circles and arcs is smooth. 0 Circles and arcs are not smooth, but rather are displayed as a series of vectors 1 Circles and arcs are smooth, displayed as true circles and arcs If you have a Multicore Computer WHIPTHREAD Type:IntegerSaved in:RegistryInitial value:1 Controls whether to use an additional processor to improve the speed of operations such as ZOOM that redraw or regenerate the drawing. WHIPTHREAD has no effect on single processor machines. 0 No multithreaded processing; restricts regeneration and redraw processing to a single processor. This setting restores the behavior of AutoCAD 2000 and previous releases. 1 Regeneration multithreaded processing only; regeneration processing is distributed across two processors on a multiprocessor machine. 2 Redraw multithreaded processing only; redraw processing is distributed across two processors on a multiprocessor machine. 3 Regeneration and redraw multithreaded processing; regeneration and redraw processing is distributed across two processors on a multiprocessor machine. When multithreaded processing is used for redraw operations (value 2 or 3), the order of objects specified with the DRAWORDER command is not guaranteed to be preserved for display but is preserved for plotting. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted November 19, 2012 Share Posted November 19, 2012 Modern computers should easily handle VIEWRES=20000 While the computer might "handle it" what is the point if you can't see the difference. I recommend setting at the lowest setting (faster speed) that doesn't bother your sense of aesthetics with faceted edges on circles. I set my template at 2000. Increasing resolution of arcs beyond what you can see only slows down the computer with no benefit. Quote Link to comment Share on other sites More sharing options...
rkent Posted November 19, 2012 Share Posted November 19, 2012 I keep mine set to 500 and occasionally have to regen. Quote Link to comment Share on other sites More sharing options...
f700es Posted November 19, 2012 Share Posted November 19, 2012 While the computer might "handle it" what is the point if you can't see the difference.I recommend setting at the lowest setting (faster speed) that doesn't bother your sense of aesthetics with faceted edges on circles. I set my template at 2000. Increasing resolution of arcs beyond what you can see only slows down the computer with no benefit. While this is a very logical statement I doubt any modern computer will be phased by the difference. Or at least it will not be noticeable by a human eye. As a test a drew a circle, ran an array command and achieved 11,016 circles in Acad 2013. I exploded the array so I had individual circles. I set viewres to 2,000 and typed regen. Instant regen. I set viewres to 15,000 and typed regen. Instant regen, no delay at all. My system monitor I run showed no difference between the settings. Sure different PCs with different setups will and can yield different results I see no difference what so ever on my PC at work. I might try this at home and see what happens there. Whipthread was set to 1 during the above test. I set it to 3 and still response feedback was instant. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 19, 2012 Share Posted November 19, 2012 I too see no point in setting viewres any higher than 5000. But if any of you want to max it out then that is entirely your choice. Go for it. Quote Link to comment Share on other sites More sharing options...
Dana W Posted November 20, 2012 Share Posted November 20, 2012 :PSome people drive Shelby Mustangs to get some ribs and beer, and some people ride a recumbent bike to the yogurt bar. Quote Link to comment Share on other sites More sharing options...
f700es Posted November 20, 2012 Share Posted November 20, 2012 I vote for the Shelby to get ribs and beer! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 20, 2012 Share Posted November 20, 2012 We are looking for a volunteer for the designated driver ... taxi? :beer: I'm planning on recalibrating my VIEWRES to 0! Quote Link to comment Share on other sites More sharing options...
