Results 1 to 7 of 7
    Senior Member SunnyTurtle's Avatar
    SunnyTurtle's Computer Details
    Win 10 64bit
    Civil
    SunnyTurtle's Discipline Details
    Drafter CAD
    Civil
    Rail, Roads, Civil
    AutoCAD 2018
    Apr 2011
    Sydney Australia
    161
    Default lisp to change visablite state of a dynamic block
    Hi was trying to create a lisp that would change the visablity state of this block if it was inserted into a drawing can anyone help
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    Code:
    (defun c:demo (/ ss ans i blk dp)
      	(if 	(and (setq ss (ssget "_:L" '((0 . "INSERT"))))
    		     (not (initget 1 "circle square "))
    	  	     (setq ans (getkword "\nChoose Visibility [circle/square]: ")))
    		  	(setq blk (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
    		  	(cond ((and
    				   (eq (vla-get-IsDynamicBlock blk) :vlax-true)
    			       	   (setq dp (car
    					    (vl-remove-if-not
    					      '(lambda (k)
    						 (eq
    						   (vla-get-PropertyName
    						     k
    						   "Visibility1"
    					      (vlax-invoke
    						blk
    						'GetDynamicBlockProperties
    			       	(vlax-put dp 'Value ans)
    Win 10 64bit
    Civil
    Drafter CAD
    Civil
    Rail, Roads, Civil
    AutoCAD 2018
    Apr 2011
    Sydney Australia
    161
    Hi im am having problem running the lisp it seems to fail at the line (LAMBDA (K) (EQ (vla-get-PropertyName K) * "Visibility1" *))
    when i run the script i get this error: AutoLISP error - too many arguments
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    Quote Originally Posted by SunnyTurtle View Post
    Not sure where you get that "*" on the lambda function , besides i was missing a pair of parenthesis.
    "Visibility1" is the visibility parameter name on your DBlock. This code wont do a thing if the name does not match.
  5. #5
    Win 10 64bit
    Civil
    Drafter CAD
    Civil
    Rail, Roads, Civil
    AutoCAD 2018
    Apr 2011
    Sydney Australia
    161
    Thanks i remove
    *'s and it worked
    as i just copyed in to visual lisp editor.
    Thankyou so much for your help i was having trouble with a lisp of mine and this code will be easy to modify and add to my lisp
  6. #6
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    Thanks i remove
    *'s and it worked
    Good for you, glad it helps
  7. #7
    Win 10 64bit
    Civil
    Drafter CAD
    Civil
    Rail, Roads, Civil
    AutoCAD 2018
    Apr 2011
    Sydney Australia
    161
    I have create a new Thread with a related question
    Here is my code as of today
    Code:
    (defun c:set1 (/ ss ans i blk dp scale)
          (not (initget 1 "1:1 1:2 1:2.5 1:5 1:10 1:20 1:25 1:50 1:100 1:200 1:250 1:500 1:1000 1:2000 1:2500 1:5000 1:50000 "))
       (setq ans (getkword "\nChoose Visibility [1:1/1:2/1:2.5/1:5/1:10/1:20/1:25/1:50/1:100/1:200/1:250/1:500/1:1000/1:2000/1:2500/1:5000/1:50000]: ")
         (cond (and
                  (setq dp (car
             (vl-remove-if-not
               '(lambda (k)
           (eq
               k
             "RMS_SCALE_VIS"
               (vlax-invoke
          blk
              (if (eq ans "1:1") (setq scale "RTA_SCALE_1"))
                     (if (eq ans "1:2") (setq scale "RTA_SCALE_2"))
              (if (eq ans "1:2.5") (setq scale "RTA_SCALE_2.5"))
              (if (eq ans "1:5") (setq scale "RTA_SCALE_5"))
              (if (eq ans "1:10") (setq scale "RTA_SCALE_10"))
              (if (eq ans "1:20") (setq scale "RTA_SCALE_20"))
              (if (eq ans "1:25") (setq scale "RTA_SCALE_25"))
              (if (eq ans "1:50") (setq scale "RTA_SCALE_50"))
              (if (eq ans "1:100") (setq scale "RTA_SCALE_100"))
              (if (eq ans "1:200") (setq scale "RTA_SCALE_200"))
              (if (eq ans "1:500") (setq scale "RTA_SCALE_500"))
              (if (eq ans "1:1000") (setq scale "RTA_SCALE_1000"))
              (if (eq ans "1:2000") (setq scale "RTA_SCALE_2000"))
              (if (eq ans "1:2500") (setq scale "RTA_SCALE_2500"))
              (if (eq ans "1:5000") (setq scale "RTA_SCALE_5000"))
              (if (eq ans "1:50000") (setq scale "RTA_SCALE_50000"))
               (vlax-put dp 'Value scale)
  1. lisp to change dynamic block visibility
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Mar 2013, 12:39 am
  2. Dynamic Block Lost Visibility State
    By Deginault in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Sep 2012, 02:21 pm
  3. Dynamic block visual state
    By Accoes in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th May 2011, 04:10 pm
  4. change the visibility list of a dynamic block by lisp
    By alijahed in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th May 2010, 01:55 am
  5. Refer to a dynamic block visibility state VBA
    By kyosmith in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Apr 2010, 01:18 pm
