Print WHITE - over imposed image
Guys,
I am trying to print some white text / couple of lines over top of an image in white - so that they do not blend in after the drawing has been printed...
I am using monochrome printing status - and have set the color printing to (use object color), and set the 'screening' value to '0'.
I have ensured that the color 'white' unde rplot styles is also set to 255,255,255...
I have ensured that the printer configuration for 'Merge Control' is set to 'Lines Overwrite'...
Yet its till prints the lines in Black!!!
The only thing I noticed is that when you look at the layer table itself it still shows the plotter to overwrite white with color : 'color_7' which is black correct??
however the option is greyed out so that you cannots elect or change it... And I cannot find anywhere to alter this color overwrite 'plot style' as it is labelled...
anyone have any ideas? do I just need to change this 'plot style' setting? where can I find this??
Many thanks!
