Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member Ahmeds's Avatar
    Ahmeds's Computer Details
    Windows 7 Home Basic
    Desktop only
    G31T-M7
    Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz (2 CPUs), ~2.9GHz
    2048MB RAM
    Surveying
    Ahmeds's Discipline Details
    DPWH
    Surveying
    AutoCAD 2009
    Nov 2012
    Tanauan, Batangas, Philippines
    59
    Default Select one object/entity, gripped all same entity within the layer
    What function should i use to do that? I'm planning to change all entities in one layer but its is hard to select by windowing/crossing method because i have many entities in my drawing, so, i want to just click one but gripped all objects in the same layer to change simultaneously in just one command.
    Thanks in advance..
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,593
    QSelect / GetSel
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Desktop only
    G31T-M7
    2048MB RAM
    Surveying
    DPWH
    Surveying
    AutoCAD 2009
    Nov 2012
    59
    Quote Originally Posted by Lee Mac View Post
    QSelect / GetSel
    Thanks Lee, but as I go to Autodesk Help (AutoLisp Functions) to see an example as my reference I've notice that there is no functions such as Getsel.
    can u please give me an example of that?
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,246
    Quote Originally Posted by Ahmeds View Post
    ........... I've notice that there is no functions such as Getsel.
    GetSel is a command , and Lee gave you two options so you can use either of them
  5. #5
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    A third built-in alternative is the FILTER command.
    The GETSEL command is part of Express pack; for this reason it isn’t listed in AutoCAD’s help. If you cannot call it at command prompt, too, this may be from either the fact that you don’t have that extension installed, or that you are using the LT type of AutoCAD.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  6. #6
    Desktop only
    G31T-M7
    2048MB RAM
    Surveying
    DPWH
    Surveying
    AutoCAD 2009
    Nov 2012
    59
    Quote Originally Posted by Tharwat View Post
    Ok, I got you guys.. Thanks!
    I tried this routine to make a selection and change all text heights in just one command but all I've got is error: bad argument type: lselsetp
    Would you please help me to do this right..
    Code:
    (defun c:CTH ()
        (graphscr)
        ;(prompt "text height to change")(terpri)
        (setq a (car (entsel)))(terpri)
        (if a (setq a (cdr(assoc 8 (entget a)))
    	  	sslst(list (cons 0 "text")(cons 8 a))
        );end if
               (setq nh(getreal "New Text Height: "))
               ;(princ "\nWORKING\n")
            (setq N (sslength sslst))
              (setq n1 N)
              (repeat N
                (setq n1 (- n1 1))
                (setq b (ssname sslst n1))
                (setq c (cdr(assoc 0(entget b))))
                (if (= c "TEXT") (progn
                    (setq e (entget b))
                    (setq f (assoc 40 e))
                    (setq g (atof(rtos(cdr f)2 6)))
                    (entmod (subst(cons(car f) nh) f e))
  7. #7
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    That code attempts to treat a list as a selection set; I believe that this line:
    Code:
    sslst (list (cons 0 "text") (cons 8 a))
    should be instead:
    Code:
    sslst (ssget "_X" (list (cons 0 "text") (cons 8 a)))
    Regards,
    Mircea
  8. #8
    Desktop only
    G31T-M7
    2048MB RAM
    Surveying
    DPWH
    Surveying
    AutoCAD 2009
    Nov 2012
    59
    well, i got it now.. here it is..
    Code:
    (defun c:CTH ()
        (graphscr)
        (setq x (car (entsel)))(terpri)
        (if x (setq x (cdr(assoc 8 (entget x)))
    	  	sslst(list (cons 0 "text")(cons 8 x))
        );end if
        (setq a (ssget "x" sslst))
             (setq N (sslength a))
              (setq n1 N)
              (repeat N
                (setq n1 (- n1 1))
                (setq b (ssname a n1))
                    (setq e (entget b))
    Thank you Guys...
  9. #9
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    You should localize your variables and include the entire processing in the IF, or at least ensure that exit if user didn't select first text item. Just run your routine twice in a row, and second time do not select a text label, input a text height different than at first run and see what is happening.
    Also, please edit the above port and add the required code tags. Thank you.
    Regards,
    Mircea
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,246
    Pay attention to locked layers with the selection method "_x"
  1. Select Text Entity from Xref using .net
    By giskumar in forum .NET, ObjectARX & VBA
    Last Post: 15th Oct 2012, 05:26 pm
  2. Select all objects that are on same layer as entity selection
    By KRBeckman in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jun 2010, 04:23 pm
  3. Any way to select an entity knowing it's beginning and end locations?
    By Hudson in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Nov 2009, 08:03 pm
  4. DBX entity select mod
    By ollie in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Oct 2009, 09:19 am
  5. How select an object or entity??
    By vasqrainier in forum AutoCAD General
    Last Post: 18th Jan 2007, 04:46 am
