Pan in two MS viewports at the same time
nod684
just wondering....
i do a lot of projections when doing elevations / sections
and what i do is have the 2 viewports in model space in which the top vport shows the plan while the bottom shows the elevation / section am doing. Then using xlines, I project what is on the plan to my drawing below
now, is it possible to pan in one viewport and the other viewport follows too? can it be done thru lisp or some other tool?
Pst. I removed the dots in your title - if this thread goes over two pages, dots in the title can make it non-accessible. On second thought, I renamed the tread :thumbsup:
Good question though, I will move this to the lisp-forum and hope you get a good answer (that I can use too!)
Something like this?
;;; Pan in All Viewports (28-XI-2012)
(defun c:PAV( / oldCVPort oldCmdEcho listVPorts pointBase pointMove )
(setq listVPorts (mapcar 'car (vports))
      oldCmdEcho (getvar "CMDECHO")
      oldCVPort  (getvar "CVPORT"))
(setvar "CMDECHO" 0)
(if (and (setq pointBase (getpoint           "\nBase point: "))
         (setq pointMove (getpoint pointBase "\nNew point: ")))
 (foreach itemVPort listVPorts
  (setvar "CVPORT" itemVPort)
  (command "_PAN" pointBase pointMove)
(setvar "CVPORT"  oldCVPort)
(setvar "CMDECHO" oldCmdEcho)
  • 1 year later...
please anyone could help on this issue
New point: int of ; error: AutoCAD variable setting rejected: "CVPORT" 1
Edited by SLW210
Added Code Tags
kindly observe proper posting of codes...
must be inside quotes.
anyway, i did not get this error. still using it till now.
Im using AutoCAD 2014
Edited by SLW210
Yathishkumar, please pay attention that this tool is intended to be used for navigation in Model Space as per Nod684's request. Based on the error you received it appears that you attempted to use it in Paper Space.
Hi Msasu
i am using in paperspace viewports
first i click inside of one viewport and second viewport
then i type command pav
thanx
  • 4 months later...
MSasu,
How can I modify the code so that it will only pan the viewports in the current layout tab instead of trying to pan in all of the viewports in the whole drawing?
Hopefully this should fix it to be working as expected in all MS/PS situations...
(defun c:PAV ( / oldCVPort oldCmdEcho listVPorts pointBase pointMove )
(if (and (eq (getvar 'tilemode) 0)
         (eq (getvar 'cvport) 1))
 (command "_.MSPACE")
 (foreach itemVPort (vl-remove 1 listVPorts)
New point: ; error: AutoCAD variable setting rejected: "CVPORT" 2/6/1
same error like cvport 1/2/6 for defendant layouts.
may be system variable.
but it's good tool.
thanks
yathishkumar
Thanks for the code Marko. It's alot closer to what I'm looking for but when I run it, the viewport that gets activated pans correctly. My other viewport however not so much. I know the reason is that my UCS is rotated in one of the viewports. Is there any way to take this into account? Right now to pan both viewports, I draw a line in paperspace, copy it so there's an identical line on top of both vports, then chspace the line into each vport and then use -pan command end select the end points of the line so the view pans the direction and distance equally.
  • 2 years later...
Hello Guys, this is two years old, but a very useful thread! Thank you very much to all who contributed. I'd like to ask if the lisp could also correct same zoom between two MS viewports while it pans with the PAV?
Cheers!
