+ Reply to Thread
Results 1 to 10 of 10
  1. #1
    Forum Newbie
    Using
    AutoCAD LT 2012
    Join Date
    Nov 2012
    Posts
    2
    Default rotated drawings
    I have forgotten how to draw a line that is parallel to a building wall which is not either horizontal or vertical. Getting old!!
  2. #2
    Forum Deity MSasu's Avatar
    Discipline
    Construction
    MSasu's Discipline Details
    Occupation
    engineer
    Discipline
    Construction
    Details
    AutoLISP programmer
    Using
    AutoCAD 2013
    Join Date
    Mar 2009
    Location
    Brasov, Romania
    Posts
    2,986
    Default
    Are you talking of OFFSET command?
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  3. #3
    Forum Newbie
    Using
    AutoCAD LT 2012
    Join Date
    Nov 2012
    Posts
    2
    Default
    Thanks, I will try it.
    Regards,
    Geoff R
  4. #4
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,023
    Default
    You can also change the orientation of your crosshairs using the SNAPANG command as another option.
  5. #5
    Forum Deity
    Using
    AutoCAD 2002
    Join Date
    Sep 2006
    Location
    East Sussex, U.K.
    Posts
    2,963
    Default
    Or perhaps use the Parallel Osnap.
    It is unusual because you don't pick the line. You merely hover over the line until you see the deferred Osnap symbol, and then move the cursor on the indicated line, and pick the line length or enter the distance from the keyboard.
  6. #6
    Junior Member
    Using
    AutoCAD 2010
    Join Date
    Nov 2012
    Posts
    11
    Default
    Sometimes i find it useful to change the user coordinates to match the object in question. Here is the text from the command line with the user input in red.
    Command: ucs
    Current ucs name: *WORLD*
    Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>: ob
    Select object to align UCS:
    Type "plan" and the whole model space will reorientates itself to the new coordinates. To get back to the original world coordinates repeat the process using the default <World> argument rather than the "Ob".
    I have used these macros in buttons to rotate the screen 90 degrees clockwise or 90 counter clockwise. ucs;z;90;plan;; or ucs;z;-90;plan;;
    Autocad sees the ";" as and enter.
    Hope this helps.
  7. #7
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,780
    Default
    I agree with supercell you if you want don't worry about "Plan" if you have your otho turned it will draw lines etc on the correct angle it just means you turn your head a bit, the only advantage is it saves a zoom getting back to where you were.
    Almost forgot a warning when you pick OB if its 3d it will create a UCS drawing plane at a 3D angle also
  8. #8
    Luminous Being StykFacE's Avatar
    Computer Details
    StykFacE's Computer Details
    Operating System:
    Windows 7 Ultimate 64bit
    Computer:
    Dell Precision T3500
    Discipline
    Multi-disciplinary
    StykFacE's Discipline Details
    Occupation
    BIM Manager & Design Specialist
    Discipline
    Multi-disciplinary
    Details
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,483
    Default
    BIGAL is correct. Supercell's tip is the way to go, but using the OBject option can be problematic so proceed with caution. I usually manually snap to two points along a line as a reference to rotate the UCS. Alternatively, you can ax the need of the "PLAN <Enter> <Enter>" step if you utilize and enable the UCSFOLLOW system variable. I personally don't use the UCSFOLLOW command but I can see where people would find it useful.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  9. #9
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,092
    Default
    Parallel Osnap is MUUUCH easier than all that.
  10. #10
    Computer Details
    Operating System:
    Computer:
    Discipline
    Multi-disciplinary
    Occupation
    Discipline
    Multi-disciplinary
    Details
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,483
    Default
    Quote Originally Posted by SLW210 View Post
    Maybe so, depending on your situation. I know if I'm designing a complete HVAC system with 15 units and all the ducts/grilles/diffusers, etc. that go along with it in a building that has two wings, one is 38.6 degrees rotated, then I'm not spending my entire designing time using the Parallel Osnap. I'm going to reorient the drafting view to a Plan position and then go forward. Now if it's something that requires a quick design or a few PLINES, etc... then yes the Parallel Osnap can be the best method, no doubt.
Similar Threads
  1. UCS rotated?
    By ServaCleanCAD in forum AutoCAD Beginners' Area
    Last Post: 7th Jul 2010, 09:35 am
  2. Rotated UCS leads to rotated Reference Files
    By BenGoble in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Apr 2010, 01:01 pm
  3. Rotated Ucs Problem
    By Dipali in forum AutoCAD General
    Last Post: 16th May 2008, 03:40 am
  4. Rotated Dimensions
    By sharonb in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Feb 2008, 09:18 pm
  5. rotated WCS
    By Barry Clark in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Sep 2004, 04:36 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
