paulmcz Posted December 8, 2012 Share Posted December 8, 2012 JD, step 3 is a solution for this problem only. It is a shortcut for this particular case. Revolving the profile in the case like this will work as well but it is limited to radius 5 too. Just imagine what shape you end up with if you revolve a profile with radius other than 5. Quote Link to comment Share on other sites More sharing options...
paulmcz Posted December 8, 2012 Share Posted December 8, 2012 Revolved radius smaller and larger than 5, if we want the inner half-pipe intact: Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 9, 2012 Share Posted December 9, 2012 JD, step 3 is a solution for this problem only... Isn't the outside radius supposed to be 7? That is what I read in the original post. Your "solution" doesn't look correct to me. Quote Link to comment Share on other sites More sharing options...
paulmcz Posted December 9, 2012 Share Posted December 9, 2012 Outside radius of 7 on a pipe that has outside radius 5? I am trying to imagine how it should look like. To me, the only correct solution to this is that a sphere of a radius of 5 is where the 2 pipes join. Just like Remark shows in post #28. No other radius will fit there, if the two joining pipes have common center where they join. Don't you think? Quote Link to comment Share on other sites More sharing options...
paulmcz Posted December 9, 2012 Share Posted December 9, 2012 This is what I mean by sphere: Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 9, 2012 Share Posted December 9, 2012 I read the original drawing as outside radius 7 Inside radius 5 resulting wall thickness 2 The two solutions I posted both create spheres at the bends. Quote Link to comment Share on other sites More sharing options...
paulmcz Posted December 9, 2012 Share Posted December 9, 2012 OK, I see it now. It does show 7 outside radius when you look closely. My solution and everything I suggested was meant for 5 outside radius of the pipe as well as the radius of the fillet. The procedure is the same though, whether it is 5, 7 or any other number. Sorry about that. Quote Link to comment Share on other sites More sharing options...
