RBPrice Posted December 5, 2012 Share Posted December 5, 2012 I have just loaded in a Product Design Suite Professional package on a Lenovo S-30 workstation running Win 7. After the installation, I went looking for AtuoCAD 2013 and to my dismay could not find it. I pestered Autodesk to have one of their installation experts call me to try to help but that didn't work too well. With some fussing on my own, I now have a shortcut that does go to AutoCAD 2013 but I am not sure why. When I right click on the shortcut and look at the Propeties, the Start In window says AutoCAD Mechcanical 2013 and it is grayed out so it cannot be changed. This morning I tried to install the Express Tools package and to do that one must go to ADD/Remove and click on AutoCAD 2013 and do a modify. Since I do not have an AutoCAD 2013 item in the list of software packages I can't do that. Does someone have any suggestions as to how to fix this problem? Thanks very much. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 5, 2012 Share Posted December 5, 2012 Have you checked your OPTIONS, PROFILES tab? I am guessing that you may find Autocad 2013 listed as one of the available profile options. I hope that helps you out. I just reread your post, and am guessing that while possibly helpful, that won't solve your express tool issue. Have you tried the EXPRESSTOOLS command? Quote Link to comment Share on other sites More sharing options...
rkent Posted December 5, 2012 Share Posted December 5, 2012 You will have AutoCAD Mechanical showing, not plain AutoCAD so use the Mechanical choice or the Electrical one. Quote Link to comment Share on other sites More sharing options...
RBPrice Posted December 5, 2012 Author Share Posted December 5, 2012 Thanks guys - Went and did the ADD/REMOVE thingy with Mechanical 2013 and from what I saw, EXPRESS TOOLS was already installed. But when I put EXPRESSTOOLS into the Command line, the no such command answer came up. Any other suggestions? Quote Link to comment Share on other sites More sharing options...
rkent Posted December 5, 2012 Share Posted December 5, 2012 Check in options, files, for C:\program files\autodesk\autocad 2013\ express If not there then add, and make sure the express folder is at the location you add, above is only an example. And always try with a new autocad profile when stuff doesn't seem to work right. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 5, 2012 Share Posted December 5, 2012 You need to be running vanilla AutoCAD. AutoCAD Mechanical runs on top of vanilla AutoCAD - so you have everything. The problem statement is, "How to get Mechanical to run as vanilla so I have access to Express Tools." If you to to Start>Autodesk>AutoCAD Mechanical 2013 you should see a option to Runs as AutoCAD. If for some reason you do not see that option then an icon with the correct path/profile will need to be set up. Check the first (easy) option and report back what you see. this example is with Civil, but should be the same with Mechanical. Ignore the AutoCAD 2013 English folder in this image - I happen to have both installed (Civil and AutoCAD), really a wasted duplication of HDD space, but IT didn't know better. Quote Link to comment Share on other sites More sharing options...
RBPrice Posted December 5, 2012 Author Share Posted December 5, 2012 (edited) Hi JD - Start/Autodesk does NOT show and option to run AutoCAD Mechanical as AutoCAD. But I think that is what is going on because when I right click on the AutoCAD short cut and look at the Properties box there is AutoCAD Mechaniclal in the Target box but it is grayed out so it cannot be changed. I have managed to get the Express Tools running in Mechanical by Removing and re-installing it. But it does not seem to be part of what I have as AutoCAD 2013 when I do a menuload the Express Tools is missing from the list. And I have no way to Remove/reinstall it. Any chance I could get you to link to my machine via TeamViewer? As always, thanks for the help. Bob Price Edited December 5, 2012 by RBPrice Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 5, 2012 Share Posted December 5, 2012 In that case you will have to create a new desktop icon with the correct Properties to launch vanilla AutoCAD. I will be back in a bit with instructions if someone else doesn't pitch in. Quote Link to comment Share on other sites More sharing options...
RBPrice Posted December 6, 2012 Author Share Posted December 6, 2012 (edited) That would be supercalifragilistic JD Thanks Edited December 7, 2012 by RBPrice Quote Link to comment Share on other sites More sharing options...
rkent Posted December 6, 2012 Share Posted December 6, 2012 RBPrice, you simply go to the Start button, find AutoCAD Mechanical in the list under Autodesk, click and drag to desktop. Now you can modify to eliminate the mechanical portion so it will run as vanilla. Remove the /p > portion and replace with /p rbprice or whatever name you want for your vanilla profile. Quote Link to comment Share on other sites More sharing options...
RBPrice Posted December 6, 2012 Author Share Posted December 6, 2012 Super - that worked as suggested. It is interesting to me that none of the "experts" at Autodesk knew that when I finally managed to get them on the phone. Now i just need to be able to install the Express Tools into AutoCAD and that can't be done until there is a listing of AutoCAD 2013 in the Autodesk group that comes up when I bring up the Control Panel. Thanks a bunch for the help. Quote Link to comment Share on other sites More sharing options...
rkent Posted December 6, 2012 Share Posted December 6, 2012 You are over thinking this, you will not see AutoCAD in the uninstall through windows control panel, but you will see AutoCAD Mechanical 2013 or maybe AutoCAD Mechanical 2013 - English, just pick that one and go trough the process to add ExpressTools. Did you verify whether or not there is an Express folder under Programs/AutoCAD 2013 Mechanical/...? Quote Link to comment Share on other sites More sharing options...
RBPrice Posted December 6, 2012 Author Share Posted December 6, 2012 Well - I thought I had it working but it has changed back to Mechancal - I have wasted 100 hours of my time trying to get this software to run. Quote Link to comment Share on other sites More sharing options...
RBPrice Posted December 6, 2012 Author Share Posted December 6, 2012 Is there any chance you could log on to my computer using TeamViewer? I will pay for the phone call to NM Please Quote Link to comment Share on other sites More sharing options...
rkent Posted December 6, 2012 Share Posted December 6, 2012 Is there any chance you could log on to my computer using TeamViewer? I will pay for the phone call to NM Please I know nothing about TeamViewer, sorry. So you dragged and dropped the Mechanical menu choice from Windows startup which created a shortcut? yes or no Then you edited that shortcut and removed the reference to mechanical and added your own profile name? yes or no You are starting AutoCAD strictly from that shortcut? yes or no After starting from that shortcut a few times you are saying that Mechanical is starting instead? yes or no Quote Link to comment Share on other sites More sharing options...
RBPrice Posted December 6, 2012 Author Share Posted December 6, 2012 Yes to the question about dragging and creating a short cut Yes to the removal of the reference to Mechanical Yes to starting from that shortcut And yes alal that comes up is Mechanical and what is really horrible the one shortcut I had that did open in AutoCAD has now stopped doing that. As for TeamViewer it is a free to use program that lets you lock onto my desktop. Just search on it and download. Then I need to call you and give my ID and Password and lo and behold, you can move about on my machine and show me what I can't seem to get into my addled brain. All I need is your phone number sent to my email address. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 6, 2012 Share Posted December 6, 2012 let's check the properties of you vanilla desktop icon. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 6, 2012 Share Posted December 6, 2012 check your target - should be something like Make sure your Target is something like "C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\acad.exe" /P AutoCAD (where the AutoCAD Civil 3D 2013 is replaced with the appropriate folder name for Mechanical) and the Start in is something like "C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\UserDataCache\" Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 6, 2012 Share Posted December 6, 2012 after starting AutoCAD as vanilla make sure the Options> Profile shows plain AutoCAD Quote Link to comment Share on other sites More sharing options...
RBPrice Posted December 6, 2012 Author Share Posted December 6, 2012 (edited) Right now JD it is not on anything: should it be on Administration (AGM Administration) ?? Start In is" C:\Program Files\Autodesk\AutoCAD 2013\acad.exe /t" The Target is AutoCAD Mechanical 2013 English and is grayed out and cannot be changed I repeat my request to have you use TeamViewer to get to my screen - it is really easy to do. It seems to me that until I can get the Target to be AutoCAD 2013 it is not going to work. Edited December 6, 2012 by RBPrice Quote Link to comment Share on other sites More sharing options...
