AutoCad Student
  • 1 month later...
Can you tell me why My Delta X is off? My first line, referred to in the instructions on page 5 as POB, starts at this point and will extend up and slightly to the left which is equivalent to a direction of northwest actually goes back to left, not up.
Command: DDUNITS
Command: LIST
Select objects: 1 found
Select objects:
LINE Layer: "0"
Space: Model space
Handle = 1d6
from point, X=1421334.93 Y=783207.62 Z= 0.00
to point, X=1421221.79 Y=783196.81 Z= 0.00
Length = 113.66, Angle in XY Plane = N 5d27'23" W
Delta X = -113.14, Delta Y = -10.81, Delta Z = 0.00
Command: *Cancel*
Command: *Cancel*
Command:
Command: *Cancel*
Command: *Cancel*
Command: LIST
Select objects:
LINE Layer: "0"
Space: Model space
Handle = 1d6
If your line is pointing in the wrong direction it's possible you have the direction of North set incorrectly in UNITS.
See posts #4, 5, 6 and 7 of this thread (the one you are currently posting to) on how to get started with this project.
Edited by ReMark
I don't think that I do. Here is a snip of my UNITS. it shows the direction of the line behind it, then I also included a snip of my boundary layer which
is also in wrong direction.
For the line to be drawn correctly 0 degrees should be to the east, 90 degrees would then be north, 180 degrees would be west and 270 degrees would be south.
I really appreciate the help. I am just struggling with this part, I hope once I get it figured out it will go smooth. Where do I go to set the degrees for E, N, W, S. I even tried to start a new project to see if I had settings wrong, and I had the same result. I am sure I am something wrong, I just don't know where. thanks in advance.
It bears repeating, start by looking at posts #4 through 7 of THIS thread. That will get you started in the right direction figuratively speaking.
