Results 1 to 10 of 10
    Senior Member
    not specified
    Dec 2005
    106
    Default issue with copy and paste
    Hi,
    I was wondering if anyone might be able to help me with copying.
    What i've been trying to do is trying to join the two drawings together. I have two drawings, one has the actual drawing and the other one just the labels associated with the first drawing. Unfortunately, that's what i got from the other guy.
    So, i open up the first drawing and the other one that's got labels in a hope that i can copy and paste to original coordinates. When i copied the labels by selecting them all first and then chose copy. Then, switch to the other drawing and chose "paste to original coordinates".
    It didn't work and gave me a message like _pasteorig *Invalid* or _pasteclip *Invalid*
    I wonder what may cause it not to be able to copy and paste between the two drawings.
    Thank you in advance
    Forum Newbie
    not specified
    Jun 2006
    7
    there are many ways to acheive what u want to do beside copying itself,. but if i were you, i would use edit>copy with base point,.selecting the base point thats relevant to both drawing (may bethe UCS orgiin), or any other point that does exist in the both drawing,. and then just paste in the other drawing,.you should be asked for the base point to where you want to "insert" the object(S) from ur clipboard.
    hope that helps.
    and sorry if my english is not good enough
    Senior Member
    not specified
    Dec 2005
    106
    Hi Anubi5
    Thank you for your reply. I really appreciated it.
    I understand that you can copy with base point. However, i must tell you that these two files are produced by mapinfo. Apparently, mapinfo cannot produce a drawing with label or texts on it. hence, they have to be saved as a separate files.
    In the past, i have done a lot of copying and pasting job but had no problems. it just said that
    _pasteclip Duplicate definition of block BLK14755 ignored.
    Duplicate definition of block BLK26586 ignored.
    Duplicate definition of block BLK29442 ignored.
    Duplicate definition of block BLK31372 ignored.
    Do you think it might be due to the two software are in conflict or something?
    Is there anything i need to know about the mapinfo and autocad LT?
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Can you just insert the drawing with labels as block in the other drawing?
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  5. #5
    Junior Member
    not specified
    Jun 2006
    Leicester,United Kingdom
    11
    Duplication of block error messages usually occur when whey are already "hiiden" in the drawing. Try purging the drawing and insert your symbols as a Wblock.
    Failing that you could always try Xref.
  6. #6
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,427
    Quote Originally Posted by Leicesterlad30
    I agree, the drawing you are trying to copy and paste was most likely an xref that needs to be re-attached. My guess is if you open your xref manager, you will see that the drawing file is listed but not loaded. If so, just re-load it. You will need to browse to specify the location of the file on your machine. Once you do this, the drawing should load in exactly where it's supposed to be.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  7. #7
    Forum Newbie
    AutoCAD 2008
    Mar 2009
    1
    Export problem dwg file as dgn file. Then import dgn file. Copy and paste works fine after this.
  8. #8
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Quote Originally Posted by seithenyn View Post
    Good tip! But as this thread is about three years old, don't expect an answer
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
  9. #9
    Forum Newbie
    AutoCAD 2007
    Apr 2009
    1
    may be this should help you.
    just open the new document.copy all ur cad pic to new doc.
    this could be ur cad file is bad.
  10. #10
    Forum Newbie
    AutoCAD 2009
    Jul 2009
    1
    Excellent. I'm not the original thread author but this helped a bundle. Same issue. The DWGs were converted from another format as they had been originally drawn in Caddie, not AutoCAD. Just make sure all your units are set correctly before you export/import. Still post the answer even if the thread is old!
