DEG Posted December 8, 2012 Share Posted December 8, 2012 Brand new at writing a script. My question is, is it possible to create a variables (A, B, C, etc) within autocad and call those variables within a script? I've been able to write a script that generates an entity using Pline command that traces points within a .dat file, then scales that entity. The script also adds a small amount of text. I'd like to be able to call the scale factor and the text from variables. For now I'd like to stay with the scripting language, if possible. Not sure if I've explained this correctly or not, as I said, I'm just learning this so any help would be appreciated. Don Quote Link to comment Share on other sites More sharing options...
MSasu Posted December 8, 2012 Share Posted December 8, 2012 You can use the user system variables USERI1-5 (to store integrs) or USERR1-5 (for decimals): _SETVAR USERI1 3 _PLINE 0.0,0.0 _W (getvar "USERI1") 50.0,50.0 ;end of script _SETVAR USERR1 3.75 _PLINE 0.0,0.0 _W (getvar "USERR1") 50.0,50.0 ;end of script Quote Link to comment Share on other sites More sharing options...
DEG Posted December 8, 2012 Author Share Posted December 8, 2012 (edited) Thank for the quick reply Mircea. I've been able to populate the variables both from the command line and from within the script. This I've verified from the command line. Ultimately what I want to be able to do is populate several of the from the command line and then call them up from within the script. But I can't get the "getvar" line to work at all. I'll try to post a snippet of code here. Very simple....populate a variable...draw a line...and attempt to scale that line using the contents of the variable. Feeling a little dense here... _SETVAR USERI1 3 _LINE 0.0,2.0 2.0,2.0 _scale 0.0,2.0 0.0,2.0 _getvar useri1 ;end of script BTW...this code works if I just insert a numerical scale factor in place of the getvar statement.... Edited December 8, 2012 by DEG added more detail Quote Link to comment Share on other sites More sharing options...
dbroada Posted December 8, 2012 Share Posted December 8, 2012 have you tried it enclosing the getvar in ( ) & "" as shown in MSasu's code? Quote Link to comment Share on other sites More sharing options...
DEG Posted December 8, 2012 Author Share Posted December 8, 2012 I'm pretty sure I did but let me go try it again with that in mind.......BRB Didn't work....Here's what the Command Window says.... SETVAR SETVARIABLE Default: SETUSRRL1 Options: ? or Variable name» USERI1 Default: 16 Enter new value for SETUSRINT1» 16 : _LINE Options: Segments, Enter to continue from last point or Specify start point» 0.0,0.0 Options: Segments, Undo, Enter to exit or Specify next point» 0,2 Options: Segments, Undo, Enter to exit or Specify next point» : scale Specify entities» 0,0 1 found, 1 total Specify entities» Specify base point» 0,0 Options: Reference or Specify scale factor» _(getvar Requires valid numeric distance or second point, or option keyword. Options: Reference or Specify scale factor» "useri1") Requires valid numeric distance or second point, or option keyword. Options: Reference or Specify scale factor» And here is the revised code... Osnap none SETVAR USERI1 16 _LINE 0.0,0.0 0,2 scale 0,0 0,0 _(getvar "useri1") ;end of script Quote Link to comment Share on other sites More sharing options...
MSasu Posted December 8, 2012 Share Posted December 8, 2012 I spotted two issues into the script you posted: Osnap none SETVAR USERI1 16 _LINE 0.0,0.0 0,2[color=red] <-- there is an extra space[/color] scale 0,0 0,0 [color=red]_[/color](getvar "useri1")[color=red]<-- remove the underline[/color] [color=red] <-- there is an extra space and line[/color] ;end of script Your profile read AutoCAD full; please don't miss that if is LT in fact, then the AutoLISP statement will not work! Quote Link to comment Share on other sites More sharing options...
MSasu Posted December 8, 2012 Share Posted December 8, 2012 Another comment, if you simulate pick in order to get the item to scale, in some circumstances this operation may fail or get a wrong entity; since the line you are willing to process is the last drawn entity, may use the Last selection mode instead: ... _SCALE [color=magenta]_L[/color] 0.0,0.0 ... Quote Link to comment Share on other sites More sharing options...
DEG Posted December 8, 2012 Author Share Posted December 8, 2012 I do use full version 2005 but at home I have Draftsight. That's the program I've been using this script on......So, I scooted down to work and tried this on my Acad2005 and it worked with the changes you outlined above. I'll finish up this script and just use it at work. Thanks for your input and sorry to be so dense but this is new to me....Thank you all Don Quote Link to comment Share on other sites More sharing options...
DEG Posted December 8, 2012 Author Share Posted December 8, 2012 Just saw your last post and that's an great idea as I've only been picking one point...I still have a lot to learn of the conventions with script...Thanks again Mircea..... Quote Link to comment Share on other sites More sharing options...
MSasu Posted December 8, 2012 Share Posted December 8, 2012 Glad to hear that is sorted now. You're entirely welcome, Don! Quote Link to comment Share on other sites More sharing options...
