Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 51
  1. #21
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Quote Originally Posted by StykFacE View Post
    I mean, from your earlier post it sounds like all you use is 7 lineweights (eg: colors), then a few more for screening. So your need for a plot style use is probably the simplest I've ever heard of. At my company, we can't utilize that few colors. Our designs just can't take it. We might as well use all one color if all we have is 7 to choose from.
    This is basically what we use with .ctb, and even in complicated drawings (> 200 layers) it works well in my opinion.
    Also, we utilize color in our PDF plots. We have Red for clouds in our internal QA/QC. Then orange, blue and green. So we have a Named Plot Style for this because each color represents a phase in our QA/QC. For this to happen using CTB that is not ByObject, you'd have to kill a few Colors, or you'd have to use True Color to override the CTB. Good luck with standards with that method.
    We do the same with .ctb although simply used a colour plot style when we want to print pdfs in colour. I guess with .ctb you might require more plotstyles, but at the end of the day, most companies set their plotsyles up and then not touch them again for 5, 10 years etc.
  2. #22
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,151
    Like I mentioned before, to each his own. *shrugs*
    I know a guy who still draws everything on the 0 Layer and doesn't use any lineweights. He produces a lot of engineered documents, too, all in Modelspace (old school way). His background is set to White, and all linework is set to Black. So obviously I wouldn't even mention STB's to him because I know he's not changing; nor does he need to.
    Seems the only people who keep mentioning only having a handful of lineweights are Civil guys. Seems about right.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  3. #23
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,599
    Quote Originally Posted by EMS_0525 View Post
    Im not trying to be arguing here... so i hope im not coming across that way. But i want to want to use STBs. I just still dont see that big of an advantage over CTBs for me to completey change how everyone in our company thinks. Like i said the one guy uses them, and if it was that advantageous i would switch. Im just not seeing it. I just see it as the end result is the same, just a different means of getting there. Just like everything else in autocad. There is 10 ways to do the same thing.
    If you had a 50/50 split with half using ctb and half with stb then I would push for STB but in your situation I would require the one guy to not use STB. What a pain to have some files one way and some the other. The cad manager should stop that person from using STB, imho.
    The difficulty in explaining moving to STB is that people have used CTB so long it makes sense to them. But it really makes no sense to use color for b/w lineweights and it makes no sense to have to remember a pen width to color matrix or have to refer to one just to get the lineweight you need. Knowing you need color_144 to plot a black line the a width of .015, or color_244 for a 50% screening is nonsensical no matter how you slice it. Instead you would have a plot style name of BW015 and a BW50%. Which one really makes the most sense? Which one will tell almost any CAD person what your plotting intentions were if they didn't have the ctb or stb file?
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  4. #24
    Full Member
    howitzer's Computer Details
    Windows 7-64 Pro
    8GB
    nVid-something
    Civil
    howitzer's Discipline Details
    Civil Engineering Technician
    Civil
    Civil 3D 2015
    Dec 2012
    Iowa
    36
    Revit even further simplified it and I absolutely love it. You have Lineweights in Revit, but they are labeled as 1-16. 1 is thin. 16 is as thick as it gets. Easy peasy, done and done. STB's can be set up the same way. I'd rather manage 16 possibilities rather than 255 possibilities.
    To be fair, just because you have 255 possibilities with a *.ctb means they are just that... possibilities. Nowhere does it say you have to actually use all of them. If you're comfortable with a dozen options, you can use only a dozen.
  5. #25
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,151
    Quote Originally Posted by howitzer View Post
    Actually, that is false. You do have to use them - period. If you use CTB you are permanently married to 255 colors. Now if what you mean is that you don't have to utilize 255 different possible plot color options, then that's another story.
    Say you had a new higher who sat down at a CAD workstation. If he just started a job, never before seeing it and he looked over my STB file that I posted earlier, he would know exactly how to translate that without being briefed about the plot style standards. Now take the same situation but switch CTB instead. 255 possible combinations that the new higher would either have to (1) go color by color to figure out the possible combinations or (2) be taught from another employee what/why/where/how. Then, he'd probably have to keep referencing or print out the plot table. Yes I know your point about *only* using 7 colors but the point is, it's simply not the most logical or sensible, and surely not the most efficient way to leverage Plot Styles.
    But rkent's post above yours said it best: why would you use a 255 color palette for black and screened lineweights? It just doesn't make sense. Or, if you'd rather me reword that phrase to say that STB's make more sense to make you happy, then that's fine. But this continuing argument to say that Color Plot Styles make sense is just absurd because they don't, unless the CTB file is set to ByObject and you don't utilize any predefined lineweights per color option. CTB plot styles make sense because you're used to it. Any newcomer to AutoCAD would understand the STB world much quicker and easier than the CTB world.
    The only reason I'm being adamant is not to prove a point but so that newcomers to AutoCAD, if they come across this thread by chance, they have a fair chance to know the real truth. CTB's making sense... and in fact making *more* sense than STB's... is not open for debate in my book. Anybody using STB's will tell you that if they had to go back to CTB's, they'd just quit their job. Well, not really.... but you'd hear a whooooole-lotta complaining, and for good reason, ha.
  6. #26
    Full Member
    Windows 7-64 Pro
    8GB
    nVid-something
    Civil
    Civil
    Civil 3D 2015
    Dec 2012
    Iowa
    36
    Wow. That's a very wordy attempt at arguing the semantic differences between "use" and "utilize.
  7. #27
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,151
    Wow. A grammar Nazi on a CAD forum. Yay!
  8. #28
    Senior Member EMS_0525's Avatar
    EMS_0525's Computer Details
    XP
    HP xw8400 Workstation
    4GB
    250GB
    Dual Dell 18" flat screens
    Civil 3D 2013
    Nov 2008
    Pittsburgh PA
    253
    Looking at my screen i can tell how a drawing is going to print by the colors. I worked at a different company than i do now and they had many different line thicknesses assigned to almost every color. Thats absurd. I use many of the colors on my screen but most of them all print out the same. I use different colors to differentiate a concrete wall from a pipe from a tree. But i know if i have something red it will be very dark, and cyan just a little bold. So using STB's looking at the screen how do you know how something is going to print? Is there an association? Turning on the lineweights isn't an option for me, lol. I HATE that. And did i read that STBs make the file significantly larger? I have worked at 4 different drafting jobs and they all use CTBs. Like i said, STBs are newer so im guessing they are "better", so i want to give it a shot. I dont think i can though.
    There is never time to do it correct the first time, but there is always time to do it over.
  9. #29
    XP
    4GB
    250GB
    Civil 3D 2013
    Nov 2008
    Pittsburgh PA
    253
    If you're interested, here's what I consider my "base" STB file to go off of:
    https://dl.dropbox.com/u/4989089/Ima...lack%20STB.stb
    This is my own personal STB file that I use for my sidework uses. Notice the "Mask" plot style. Play with this one and see how you like it.... with Hatches, thickened Polylines, etc.
    I have downloaded that and looked it over.
    So you have 12 lineweights and 4 screenings. The CTB im using has 7 lineweights and 6 screenings. So you set a LW to a layer and i set a Color. Appears to be the exact same thing... I could see if there were different lineweights assigned to all 255 colors... but we are essentially doing the same thing. Actually I have even less "settings" than you do.
  10. #30
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    So using STB's looking at the screen how do you know how something is going to print? Turning on the lineweights isn't an option for me, lol. I HATE that.
    I know how it's going to print because I created correctly. I don't have to visualize anything. Set it and forget it. Everything is in my template. I am using colors for visual reference too. Colors, linetypes and lineweights set by-layer. I never display lineweights on the screen since AutoCAD isn't WYSIWYG.
  1. When browsing the web for application help, do you prefer.....
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 30th Jul 2011, 03:30 am
  2. Prefer text in panels, no icon
    By drwhite in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Jan 2010, 08:19 am
  3. which you prefer to use
    By e.mounir in forum AutoCAD Beginners' Area
    Last Post: 1st Dec 2008, 11:50 am
Tags for this Thread
