Sum table values
Butch
Guys hi!
Need some help.
Can AUTOCAD sum values that are entered as text values?
Attached is a table text whose right final values should be all sumed up?
Is this possible inside AUTOCAD?
Thanx!
The routine has been attached below. Download and remove the .txt portion. Load it using the Appload command. Run it by typing addtxt at the command line then press Enter. Follow the prompts. No promises made.
AddText.lsp.txt
Lisp loaded and activacted.
It asks to select object but whatever I click it says "0 object found".
I tried with text, Mtext, exploding dimensions and using their text...nothing
  • 2 weeks later...
