Page 15 of 15 FirstFirst ... 5 13 14 15
Results 141 to 145 of 145
  1. #141
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    Quote Originally Posted by JD Mather View Post
    I don't see an equation.
    This will be my last response in this thread.
    For example, I would like to draw the spline between point (1,1) and (4,3).
    The equations are:
    x
    = 1(1 t)^2 + xc 2t (1 t) + 4t^2
    y = 1(1 t)^2 + yc 2t (1 t) + 3t^2
    where
    xc = 3 and yc = 4
  2. #142
    Full Member 97catintenn's Avatar
    Construction
    97catintenn's Discipline Details
    Small Construction
    Construction
    Architecture 2014
    Oct 2007
    Johnson City, TN USA
    91
    It's better to start a new thread spinecad. While it's easy to think that you are continuing a conversation, it doesn't help the search feature for future users of the site. Each problem needs it's own thread.
    Matt
    Licensed General Contractor
    www.outdoorliving.ws
  3. #143
    Super Member PotGuy's Avatar
    PotGuy's Computer Details
    Windows 7 Premium
    Structural
    PotGuy's Discipline Details
    Temporary Works
    Structural
    (Trainee) CAD Techie/Draftsman
    Revit 2017
    Oct 2012
    London
    728
    How have we gone from 2D Tooth of Gear to a Mathematical equation?
    This space changes a lot. Normally dependant on mood.
    Smilies are abundant in my posts.
    There's no crying in CAD but there sure is a lot of whining not to mention gnashing of teeth, pulling of hair and cursing - ReMark
    There is no crying in CAD. Only mouse slamming and keyboard smashing - RobDraw
  4. #144
    Construction
    Small Construction
    Construction
    Architecture 2014
    Oct 2007
    91
    I'm still stuck on the gear, lol. I'm not sure that the teeth are evenly spaced. I used array, and chose the circle for the path, but couldn't figure out which command to use to chose the number of teeth (12) or the automaticly space them out evenly.
    First array came out perfectly spaced but with 11 teeth. So, I grabbed the grip and moused around till it look right. The bigger sprocket, after array came up a with too big of space left before the original tooth. So, I used the grip again to try to correct it.
    Thanks for posting the how-to! It's great to learn how to draw the teeth
    Matt
  5. #145
    Forum Newbie
    not applicable
    Jul 2014
    5
    Default spur gears: dxf profile
    Quote Originally Posted by spinecad View Post
    Hi,
    Could anybody please give me an easy example of how to create a 2D drawing (standard mechanical engineering drawing) of one tooth of gear such as below image?
    http://i47.tinypic.com/fbi82g.png
    Thank you
    You could try to use the free web app at www.me-bac.com to involute a spur gear and download the dxf profile. Bye.
  1. how to draw Spur gear tooth profile drawing in auto cad
    By asif shafiq in forum AutoCAD General
    Last Post: 12th Jul 2014, 09:35 pm
  2. Helical Gear Tooth Profile
    By wasim khan in forum AutoCAD Beginners' Area
    Last Post: 6th Jan 2014, 12:11 am
  3. Bevel Gears (again) - how to modify the non-tooth body of the gear
    By Gary Barker in forum Autodesk Inventor
    Last Post: 22nd Nov 2011, 07:10 pm
  4. How to draw gear like this?
    By Random one in forum AutoCAD Beginners' Area
    Last Post: 24th Aug 2009, 06:37 pm
  5. how do i draw a gear
    By alain in forum AutoCAD General
    Last Post: 24th Sep 2006, 10:21 pm
