Page 2 of 15 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 145
  1. #11
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Next draw this cyan (blue) arc and yellow arc.
    The centers of these arcs are on the red circle.
    There is a bit of a trick to locating the center points - post back if you don't know the trick.
    Post your file here when you have finished this step.
  2. #12
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    Quote Originally Posted by JD Mather View Post
    Attachment 39374
    I don't know the trick.
  3. #13
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    The trick is to simply draw a circle with the desired radius (in this case big_R or r.2675) with the center at a location that you do know. Where that circle passes through the reference circle is one of two possible locations for the desired centerpoint. The one of the two possible points you need is visually obvious.
    Center Trick.PNG draw second yellow arc at rightmost intersection of yellow arc shown and red arc. Delete the original yellow circle and trim the second yellow circle beween the pitch circle and the addendum circle as shown in my earlier post.
    Repeat for little_r
  4. #14
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    Attachment 39378 draw second yellow arc at rightmost intersection of yellow arc shown and red arc. Delete the original yellow circle and trim the second yellow circle beween the pitch circle and the addendum circle as shown in my earlier post.
    Repeat for little_r
    This is my gear in the attached .dwg file.
    Why the shape of the tooth is different compared to the attached image?
  5. #15
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    Where is its epicycloid and the hypocycloid?
  6. #16
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Where did that come from.
    I didn't instruct you to do that?
    In my first reponse I asked if you could follow instructions!
    I guess I didn't write it exactly like that, but
    Are you willing to work through the entire process - beginning to end (read, not so easy)?
    I was walking you to the solution step-by-step. You missed my last step.
    Post file that looks like #13.
  7. #17
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    I guess I didn't right it exactly like that, but
    I thought that was the last step.
    I will post the .dwg file that looks like #13.
  8. #18
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Got to pay attention in class.
  9. #19
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    This is the .dwg file that looks like #13.
  10. #20
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Now draw circle with center at intersection of yellow circle and red circle as shown.
  1. how to draw Spur gear tooth profile drawing in auto cad
    By asif shafiq in forum AutoCAD General
    Last Post: 12th Jul 2014, 09:35 pm
  2. Helical Gear Tooth Profile
    By wasim khan in forum AutoCAD Beginners' Area
    Last Post: 6th Jan 2014, 12:11 am
  3. Bevel Gears (again) - how to modify the non-tooth body of the gear
    By Gary Barker in forum Autodesk Inventor
    Last Post: 22nd Nov 2011, 07:10 pm
  4. How to draw gear like this?
    By Random one in forum AutoCAD Beginners' Area
    Last Post: 24th Aug 2009, 06:37 pm
  5. how do i draw a gear
    By alain in forum AutoCAD General
    Last Post: 24th Sep 2006, 10:21 pm
