Page 3 of 15 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 145
  1. #21
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Delete the first yellow circle and trim the second yellow circle as shown below.
    Repeat this process with the cyan (little_r) arc as shown earlier in post #11.
    Attach the file here.
  2. #22
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Radial line.jpgDraw line (shown green) from then end of the cyan arc to the center of the gear.
  3. #23
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Add green Root Fillet as shown.
  4. #24
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Rotate the vertical line -7.5° as shown.
    I think you can figure out the rest.
    (Join, Mirror, Trim, Array)
    there are 12 teeth in this design.
    Post back solution or further questions and I will attach the xls (can be set to any number over 12 teeth).
  5. #25
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    Quote Originally Posted by JD Mather View Post
    Attachment 39402
    The yellow circle shown on above is not similar with the yellow circle you shown on the #13.
    I can't continue because of this.
  6. #26
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    Sorry, I think I skip the #20.
    Now I can continue.
  7. #27
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    Another problem, I don't know how to make the cyan arc in #11.
    I can not continue.
  8. #28
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    make the cyan arc exactly like the yellow arc was made, but with a radius of .109167 (little_r)
    draw the circle with the center at the intersection of the red lines - just like the first yellow circle was drawn.
    draw second cyan circle where it intersects the red circle - just like was done with the second yellow circle.
    delete the first cyan circle
    trim the second cyan cirle
    If you still can't figure it out post back and I'll do step-by-step pictures
  9. #29
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    Unlike the yellow circle/arc, the problem is I can not find the center of the cyan circle.
    The center of the yellow circle is known at the quadrant on the top of the white circle (D1.0000).
  10. #30
    Senior Member
    Mechanical 2012
    Dec 2012
    133
    Meanwhile, come take a look at my current work.
    I don't know whether it's correct or not.
  1. how to draw Spur gear tooth profile drawing in auto cad
    By asif shafiq in forum AutoCAD General
    Last Post: 12th Jul 2014, 09:35 pm
  2. Helical Gear Tooth Profile
    By wasim khan in forum AutoCAD Beginners' Area
    Last Post: 6th Jan 2014, 12:11 am
  3. Bevel Gears (again) - how to modify the non-tooth body of the gear
    By Gary Barker in forum Autodesk Inventor
    Last Post: 22nd Nov 2011, 07:10 pm
  4. How to draw gear like this?
    By Random one in forum AutoCAD Beginners' Area
    Last Post: 24th Aug 2009, 06:37 pm
  5. how do i draw a gear
    By alain in forum AutoCAD General
    Last Post: 24th Sep 2006, 10:21 pm
