Results 1 to 9 of 9
Thread: printer options
    Full Member 084x4larry's Avatar
    Structural
    084x4larry's Discipline Details
    steel detailer
    Structural
    AutoCAD 2012
    Aug 2012
    69
    Default printer options
    what is the process to get the autocad print/plot dialogue box to open up already choosing a certain printer out of the available ones you may have?
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Page set up.
    Drafting is a breeze.
    Structural
    steel detailer
    Structural
    AutoCAD 2012
    Aug 2012
    69
    Quote Originally Posted by RobDraw View Post
    Page set up.
    Appreciate the response but its so vague im not sure what u mean. but when i invoke plot in an autocad session i immeditatly get a warning about it not finding the driver for some printer... i then have to skip that warning and then go in the print dialogue box and manually scroll through all my available printers and pick the one that i use 99% of the time. i know theres a way to make it already have that one chosen as soon as i invoke the print command...
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Sorry, with this in the "Drawing Management & Output" forum, I assumed you new what "page set up" meant.
    This is happening because the "page set up" is calling for a printer you do not have. You need to save the file with a proper "page set up" that calls for your printer. You can either apply the settings to the "page set up" from the plot dialog box or from the "page set up" dialog.
  5. #5
    Structural
    steel detailer
    Structural
    AutoCAD 2012
    Aug 2012
    69
    that worked. thanks. only problem is any drawing that was not saved that way will still come up asking for stuff not available... guess theres no way around that. but what u said worked. thanks again!
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,417
    1 Set up your DWT with the page setup in it set all your plot paraemeter then using "apply to layout" clicked, save this plot setup with a name then simply hit cancel the plot set up is remembered.
    2 Do plot, Click on the page setup top left, at bottom is "import" so you can open the page setup from another dwg and bring it in.
    3 after 2 if plotting multiple layouts got top left and click "previous plot" "apply to layout" and save dwg as normal.
  7. #7
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    I think there is a way to assign a printer to replace one that is not present instead of AutoCAD's default to go to the None printer, but I cannot find it at the moment.
  8. #8
    Junior Member
    AutoCAD 2013
    Oct 2012
    14
    Hi not sure what your options are in 2011 but if you go to "options" do you get a plot publish tab? You can in the later version set your default printer there. I'm not sure if this will change your default printer for any other software though.
  9. #9
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    That alone does not change AutoCAD behavior of switching to the "None" printer when the assigned printer is not available.
  1. Using my old printer
    By Thaumaturge in forum Hardware & Operating Systems
    Last Post: 30th Jun 2011, 02:43 pm
  2. How do I script a printer change - <Network> printer name has spaces in it??
    By ILoveMadoka in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 4th Jan 2011, 08:14 pm
  3. A3 Printer
    By jackdaniels in forum AutoCAD Beginners' Area
    Last Post: 12th Jul 2007, 12:22 pm
  4. HP Printer
    By KAD in forum AutoCAD Beginners' Area
    Last Post: 7th Apr 2007, 08:18 pm
  5. New printer
    By Angus in forum AutoCAD General
    Last Post: 16th Aug 2005, 09:34 am
