Results 1 to 4 of 4
    Junior Member amanda phillips's Avatar
    Civil 3D 2007
    Jul 2007
    Wales, UK
    15
    Default 2013 running slow
    We are having trouble with some of the PC’s in the office running very slowly.
    We are all running AutoCAD civil 3D 2013, however when we open the same drawing on different machines some machines are painfully slow while others are ok.
    The main problems seem to be :-
    • when switching between tabs (there are 9 layout tabs) some PC’s take 4/5 seconds while others take up to 60 seconds.
    • Hatching some pc’s are fine while others are painfully slow – that is if they don’t crash.
    The operating systems on all of the pc’s are similar
    We are operating
    Microsoft windows XP Professional Version 2002 service pack 3
    Intel® Core™2 CPU
    E8400@3.00GHz
    3.00GHz, 3.24 GB of RAM
    NVIDIA Quatro FX 1700
    This problem is very frustrating and we are puzzled how it seems to occur on 3 out of 8 of our PC’s.
    I would be very grateful if someone could advise us
    Thank you
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,595
    First things to try - set one at a time and test until you find the culprit.
    HPQUICKPREVIEW set to 0
    HPDLGMODE set to 0
    Dock the command line.
    Set hardware acceleration on.
    Turn the layer manager off.
    Turn off Selection Cycling, SC button at the bottom of the screen.
    Turn PROPERTIES off.
    Set FIELDEVAL to 4.
    Start AutoCAD with a new profile on the trouble machines as a test.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Civil 3D 2007
    Jul 2007
    Wales, UK
    15
    Thank you for your reply.
    I tried altering the settings you suggested but unfortunately they didn't cure the problem.
    I just noticed that some of the PC's (the slow ones) were missing a SHX file - created by MX - I have inserted the file and they are a lot quicker. Acad must have been looking for the file when switching tabs.
    Thanks again for your reply
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,744
    Yep, usually one PC being slow is either a setting / files missing / folders missing / something using too much RAM. You could always use Process Monitor to check where the failed attempts occur.
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  1. AutoCAD 2013 on Mac running SLOW!
    By russ_1989 in forum AutoCAD Beginners' Area
    Last Post: 15th Sep 2012, 04:33 pm
  2. Cad is running slow
    By souvik in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 9th Jul 2012, 10:35 am
  3. Inventor running very slow
    By sadil in forum Autodesk Inventor
    Last Post: 3rd Oct 2011, 12:52 pm
  4. Bit Of A CAD Drawing Problem - running slow
    By GA-CAD in forum AutoCAD General
    Last Post: 10th Dec 2009, 11:48 am
  5. 2009 LT Running Slow
    By YZ in forum AutoCAD General
    Last Post: 21st Aug 2008, 06:00 am
