Results 1 to 4 of 4
Thread: Fillet problem
    Forum Newbie
    AutoCAD 2010
    Oct 2012
    7
    Default Fillet problem
    Hi, I'm on AutoCAD 2012 student version, Penn Foster Civil Drafting Plate 2, and I keep getting an error message "Cannot fillet between these two entities". I'm trying to fillet between a circle and a line (west quadrant). The circle radius is 25 and the fillet radius is 20. My main concern is that I am quite certain I have drawn all the entities correctly, and if I can't fillet this, I can't proceed with the rest of my drawing. It's for a cul-de-sac at the end of a driveway.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Try adding a circle with the TTR (tangent tanget radius) option instead.
    That will ALWAYS work.
    Attach the result image here.
    assuming you did create everything correctly the trim will then be obvious.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by Chizzel3 View Post
    BTW - you should always specify units. Is this millimeters, meters, kilometers, inches, feet, miles?
    Forum Newbie
    AutoCAD 2010
    Oct 2012
    7
    You are AWESOME! Thank-you so much. You don't know how much I struggled with this and looked up other resources before posting it. What a relief. (Of course it worked.) And thank you for advising me about adding the drawing units. I will do so in the future.
  1. Fillet problem
    By Bogbadbob658 in forum AutoCAD Beginners' Area
    Last Post: 26th Mar 2012, 04:00 pm
  2. Problem with fillet
    By gpd in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Nov 2010, 09:47 am
  3. Fillet problem
    By kashlin in forum AutoCAD Beginners' Area
    Last Post: 28th Dec 2008, 04:53 pm
  4. Fillet Problem
    By Laurel in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Oct 2008, 01:26 am
  5. Fillet Problem
    By p1nkninja in forum AutoCAD Beginners' Area
    Last Post: 8th Oct 2008, 09:28 pm
Tags for this Thread
