Moving 3d objects to touch face
danielk
Im trying to move objects correctly , lets say from one to top of another .
Untill now im swithching to desired view ( top, right, left etc...) and then moving . if my base point is a vertex and the point i want it to be attached it also a vertex , i have no problem. the problem starts when im trying to move object from their center point or other non vertex points to touch the face of the other object.
in the file i attached there's two rectangles i want to move the small one in top of the big one in the Z axis only , so i switched to the view i want but still unable to move it to the next face . Ive tried playing with 3d object snap , no success.
i hope i got myself clear (sorry for my English , not my mother language) 332.JPG
151.dwg
  • Replies 35
  • SEANT
    11
  • danielk
    9
  • ReMark
    3
  • JD Mather
    3
Posted Images
Coordinate Filters work fairly well for that type of task. See the Command Line sequence below, along with the GIF animation in ZIP file.
Command: MOVE
Select objects: 1 found
Select objects:
Specify base point or [Displacement] :
Specify second point or : .xz
of @
(need Y):
Filters.zip
Couldn't the problem be avoided by switching to one of the isometric views and a 2D wireframe visual style so the user can see where picks are being made?
I may be reading more into the request than I should but it sounds like the objective is to move the objects face to face without additional displacement. For example, in the 151.dwg, the bottom face of the smaller solid would come into contact with the top face of the larger without any movement in the WCS XY plane. The end result would amount to a displacement of 0,0, -4770.3943
I believe you have it right there SEANT.
I mistook the issue and
I posted without having looked at the .dwg, never mind. :beer:
I usually do that with the help of a throw away polyline created in an appropriate ortho view,
from any OSNAP on the bottom of the little object, to the PERPENDICULAR snap on the top of the other object.
When moving I choose the ENDPOINTS of the polyline, as I know they are parallel to the UCS.
Sounds like a convoluted way to improvise a point filter, which I never learned when I started with the software. :)
Edited by Dadgad
Command: MOVE
Select objects:
of @
(need Y):
yes you are right , thats was my purpose . i follow your instruction but i cant get to work , maybe something is turn on/off that doesnt supposed to be?
I mistakenly made the process more confusing than it should have been. I thought the viewport on the right (in the 151.dwg file) was “Right” View/UCS, when it was actually still WCS.
To be more specific:
Coordinate filters do adhere to the current UCS. If the current coordinate system is World, and the objective is to move an object in only the Z direction, then the command sequence sould be:
(text in red italics are notes on what should be done at that point)
Command:MOVE Select the smaller solid
Select objects: Hit Enter
Specify base point or [Displacement] : With End osnap running, select bottom corner of small solid
Specify second point or : .xy Input “.xy” at prompt
of @ The “@” symbol registersthe previous picked point to zero the X and Y coordinate
(need Z): .z Input ".z" and select a point on the top face of the larger solid
None of AutoCAD’s coordinate restriction methods are particularly fluid. Coord Filters, Osnap Tracking, 3D Gizmo are not a hell of a lot better than temporary construction geometry.
The Coordinate Filters set up as a macro are pretty good. Or, at least a little bit faster. (see animation)
As example, OnlyX:
Filter2.zip
i looked at the animation , looks like a good soulotion for my needs. i dont know how to create the macros and how to insert them in the "right click menu", as i see its through the CUI. i will try to create it somehow. Thanks
As a quick listing of steps –
Invoke the CUI command to present the cui editor.
1. Create a new command
2. Give the command a name and insert the appropriate macro
.yz;@;
For OnlyX
.xz;@;
For OnlyY
.xy;@;
For OnlyZ
.z;@;
For OnlyXY
3. Drag the new command up to the Shortcut Menus – Command Menus
o.ki got confused too much, tried the move the smaller object to touch the face of the larger one .
i chossed the object>Enter
typed : ".xy" Enter
typed: ".z@" and chossed the upper point of the large object ,Enter.
sometimes it moves , sometimes it doesnt move to the desired point , what is the logic beyond it ?
Sorry. It appears I’ve still left out a step or two in my description.
Specify second point or : .xy Input “.xy” at prompt then
of @ at the “of” prompt type “@” then
(need Z): Select point at destination position. I had originally claimed that a “.z” was needed – actually, it doesn’t matter if the “.z” is included or not.
O.K I got it , but now after digging to this subject i found point filters already exist in autocad 2013 by default so the process is like that :
1) i switched to right view (upper left corner) .
2) i type MOVE (move command ofcourse) select the smaller object (if you are in right view , the smaller object will appear above the bigger one). hit ENTER
3)after selection i click on the base point ( left bottom corner) hit ENTER
4)now i press the SHIFT+RIGHT CLICK and a shortcut menu will appear. I move to the "point filter" tab and another small window will appear. i will click on the .xz (thats the point im filtering beacuse i want the move the smaller object only in the Y direction ).
5)then i click again on the same left bottom corner. this CLICK(lets call it click16 just for the record) determine from where the rectangle will move if ill click any other place it will move the object from that point to the next point (next step) but still in the y direction from click16. (SAME RULES FOR OTHER POINT FILTERS)
6) now i choose the upper left corner of the bigger object and click again , thats it , now the small object is located on the top of the surface of the bigger one.
Thats like what you said but i see this function already exist in 2013 , i wrote it to myself and for others maybe someone will find it useful. but its all with your help SEANT ofcourse, thank you very much its an issue i was dealing with for long time.
Edited by danielk
Can you attach a before and after dwg?
I still get the feeling this is more work than actually needed.
Maybe I don't understand the problem. A file might be worth 10,000 words.
JDM: Post #1 has a file attached.
The OP states he wants to move the smaller object from its center to the top of the larger object. He does not say where on the object however.
Personally I would switch to a 2Dwireframe visual style and use one of the four default isometric views so I can see what I am grabbing and where I am going. To move the smaller object by its center I would use the Move command with the M2P modifier. If the smaller object is being moved to an OSnap on some portion of the larger object's geometry then its a breeze to complete the move command. However, if it is not being moved to one of those points then another method has to be utilized to obtain the final correct positioning.
....I would still need the end result to be certain of the design intent.
If I understand the problem I would create a diagonal line on each and then move. Done.
If they weren't already lined up with desired contact faces then I would Align and then move using the diagonal lines .
I normally only work with one viewport.
Nicely done, danielk. It looks like you have a good handle on point filters.
Admittedly, there is a slight language barrier but, based on confirmation in a latter post, I think this is the task intent. If the file in Post # 1 is the “before”, this would be the “after”.
151After.dwg
