Results 1 to 5 of 5
    Senior Member khoshravan's Avatar
    khoshravan's Computer Details
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Default what is the proper software fro drawing a pipeline layout and its deformation?
    I have a 2D pipeline layout. Nodes on the pipe are known by their X and Z coordinates. A FORTRAN written code calculated the nodes displacement in 2 direction of x and z.
    I have to draw the nodes, connect them to each other to obtain pipeline layout and then draw the x and z deformations separately to show the deformed shape.
    Input format is like
    PN x y z
    1 0 0 0
    2 0 0 10
    10 0 0 100
    20 10 0 100
    40 40 0 100
    I though ACAD might be an easy tool to do this. I am trying to use MacLee's or Geobuilder's LISP routine to import the x and z coordinates into CAD.
    MAcLee's routine doesn't recognize node numbers at the beginning. So I shifted into Geobuilder's rotine. Still I am trying to use but with no lock till now.
    Do you know any easier method for drawing these simple stuff, coordinates and deformation? Is it possible easily in ACAD?
    My other limitation is that ACAD is the only software I have in my hands.
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    You might try the lisp routine "ascpoint" at http://www.cadforum.cz/cadforum_en/download.asp
    which can draw polylines from text file information. handles point numbers as far as I know.
    Full Member NEXTMARCUS's Avatar
    NEXTMARCUS's Computer Details
    windows xp; windows 8
    Mechanical
    NEXTMARCUS's Discipline Details
    Design tracer
    Mechanical
    AutoCAD 2013
    Dec 2012
    Rio, Brasil
    50
    Hi khoshravan here i use caesar II ,its a stress analysis software its calculates the displacements and the stress in the pipe, it also exports the model in isometric view to a .dwg file but i dont know a software to plot the displacements in 2d layout.
    Mechanical
    Design tracer
    Mechanical
    AutoCAD 2013
    Dec 2012
    Rio, Brasil
    50
    you could try to use excel to prepare the data to be exported to autocad by the lee mac program, using the comand text to columns:
    after the process you can copy /paste the data to a text file or create a columns with ";" , merge with the other and save as a .csv file , then you can use lee macs program to import the data.
    Sorry about my very bad english.
  5. #5
    Mechanical
    Design tracer
    Mechanical
    AutoCAD 2013
    Dec 2012
    Rio, Brasil
    50
    I used the Geo_Import_v2_7 with the coords u gave above and it worked very well.
  1. Pipeline route profile (graph)
    By kevin_900922 in forum AutoCAD General
    Last Post: 16th May 2012, 04:03 am
  2. Pipeline Linetype
    By YZ in forum AutoCAD Beginners' Area
    Last Post: 9th May 2011, 03:18 am
  3. Pipeline Longitudinal Profile
    By viriato79 in forum Autodesk Software General
    Last Post: 25th Apr 2011, 12:21 pm
  4. Measure Deformation
    By jinda in forum Autodesk Inventor
    Last Post: 3rd Feb 2009, 10:01 pm
  5. setting up a drawing to proper scale
    By STEVE M RICE in forum AutoCAD General
    Last Post: 25th Oct 2004, 10:04 pm
Tags for this Thread
