khoshravan Posted January 20, 2013 Share Posted January 20, 2013 I have a 2D pipeline layout. Nodes on the pipe are known by their X and Z coordinates. A FORTRAN written code calculated the nodes displacement in 2 direction of x and z. I have to draw the nodes, connect them to each other to obtain pipeline layout and then draw the x and z deformations separately to show the deformed shape. Input format is like PN x y z 1 0 0 0 2 0 0 10 10 0 0 100 20 10 0 100 40 40 0 100 I though ACAD might be an easy tool to do this. I am trying to use MacLee's or Geobuilder's LISP routine to import the x and z coordinates into CAD. MAcLee's routine doesn't recognize node numbers at the beginning. So I shifted into Geobuilder's rotine. Still I am trying to use but with no lock till now. Do you know any easier method for drawing these simple stuff, coordinates and deformation? Is it possible easily in ACAD? My other limitation is that ACAD is the only software I have in my hands. Quote Link to comment Share on other sites More sharing options...
CarlB Posted January 21, 2013 Share Posted January 21, 2013 You might try the lisp routine "ascpoint" at http://www.cadforum.cz/cadforum_en/download.asp which can draw polylines from text file information. handles point numbers as far as I know. Quote Link to comment Share on other sites More sharing options...
NEXTMARCUS Posted January 22, 2013 Share Posted January 22, 2013 Hi khoshravan here i use caesar II ,its a stress analysis software its calculates the displacements and the stress in the pipe, it also exports the model in isometric view to a .dwg file but i dont know a software to plot the displacements in 2d layout. Quote Link to comment Share on other sites More sharing options...
NEXTMARCUS Posted January 22, 2013 Share Posted January 22, 2013 you could try to use excel to prepare the data to be exported to autocad by the lee mac program, using the comand text to columns: after the process you can copy /paste the data to a text file or create a columns with ";" , merge with the other and save as a .csv file , then you can use lee macs program to import the data. Sorry about my very bad english. Quote Link to comment Share on other sites More sharing options...
NEXTMARCUS Posted January 22, 2013 Share Posted January 22, 2013 I used the Geo_Import_v2_7 with the coords u gave above and it worked very well. Quote Link to comment Share on other sites More sharing options...
