PaulS00 Posted January 30, 2013 Share Posted January 30, 2013 Hello, I have an alignment that I created a while back and need to extend it by adding some curves and lines to it. I right-clicked on the alignment > Edit alignment, and started adding lines and curves using the alignment tools. The alignment then appears to be lengthened, however when I pull up the properties, the length has not changed nor have the labels updated. It also won't let me add a station/offset label along the new segments. The alignment is over 3,000 feet long with many curves and I don't want to have to recreate it. Thoughts? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted January 30, 2013 Share Posted January 30, 2013 It's possible that the end of the existing alignment and the beginning of the new segments are just a microscopic space apart. If they don't meet exactly, they don't join to the alignment. Another possibility is that the new segments are part of a different, new alignment. It's easy to do. If you redefine their alignment, they should pop into place. Quote Link to comment Share on other sites More sharing options...
