Results 1 to 5 of 5
    Forum Newbie
    AutoCAD LT 2002
    Jan 2013
    2
    Default Plotting multiple DWG files to multiple PDFs automatically
    Hi!
    I'm trying to find a way to plot multiple (over a thousand) DWG files to PDF without doing each one manually. I've played around a little bit but without any luck. I'm using AutoCAD 2002 LT. Is there any way to do this?
    I've also got little to no experience with the more complex settings and abilities of autocad so when explaining please do so in laymans terms.
    Thanks very much to anyone that can help in advance!
    PS. 2002 lt has no general publish (only publish to web) option and I have no idea how sheet sets work.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Since is about LT, I believe that the only automation available is the script technology. Basically, you will need to replicate into a text file the calls of the commands to apply and also the answers to their options.
    Code:
    _OPEN Drawing path 1st
    _PLOT Plotting options
    _CLOSE
    _OPEN Drawing path 2nd
    _CLOSE
    ;end of script
    To establish the content, I suggest you to call the commands in command line mode (i.e. -PLOT) and note down the answers to their prompts. Please pay attention that if the path contains spaces will have to place it in quotes.
    To create the list of the files to plot create a BAT file with the code below; next use Excel (or other spreadsheet application, for that matter) and build the script.
    Code:
    DIR /b *.* > drawings.txt
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Forum Newbie
    AutoCAD LT 2002
    Jan 2013
    2
    Thanks for the reply Mircea! I'll have a go at work tomorrow and see how I go. Once again thank you very much!
    Senior Member
    hoss's Computer Details
    Windows 7 - 64 Bit
    Dell Precision T1600
    MEP 2012
    Jun 2007
    South Yorkshire, UK
    236
    Or you can use DWG TrueView, its free from autodesk website
    In DWG TrueView you have the option to convert , model , layouts or both while adding files to batch plot
    AutoCAD 2012 & AutoCAD MEP 2011
  5. #5
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by hoss View Post
    +1, +1, +1, +1, +1...
    Plotting to PDF has improved tremendously since 2002.
    Drafting is a breeze.
  1. Plotting from single layout into multiple files
    By AndyGrau in forum AutoCAD General
    Last Post: 21st Dec 2012, 02:21 am
  2. Multiple PDFs in one go.
    By RaamenNoodles in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2012, 03:01 pm
  3. Plotting multiple files at one time
    By Jerry98vert in forum AutoCAD General
    Last Post: 17th Jan 2009, 01:01 am
  4. Multiple Floor Plans, Multiple Files?
    By lab in forum AutoCAD Drawing Management & Output
    Last Post: 13th Mar 2008, 08:08 pm
  5. Auditing multiple DWG files automatically
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 18th Jan 2007, 08:21 pm
Tags for this Thread
