Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Junior Member
    johnseg11's Computer Details
    Windows 7
    Civil
    johnseg11's Discipline Details
    CAD Technician, Civil & Structural
    Civil
    Civil 3D 2014
    Jan 2011
    South Dennis, NJ
    14
    Default copy blocks from 1 drawing to another using paste to orig. coordinates
    In Autocad 2013, when I highlight a drawing in model space and copy, then go to new drawing and paste to original coordinates, everything comes in fine except for blocks. the blocks get thrown far away from everything else. can anyone help
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Somebody asked same question a few days ago the solution was tied to the insert point of the blocks being way out there. Those who repsonded previously will probably do so again.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Is it all blocks or multiple instances of one block?
    Is there already a definition of the block(s) in the file you are pasting into?
    Drafting is a breeze.
    Junior Member
    Windows 7
    Civil
    Civil
    Civil 3D 2014
    Jan 2011
    South Dennis, NJ
    14
    Default pasting blocks
    anything that is a block gets pasted in wrong location in 2013 using paste to original coords., in autocad 2004, the blocks come in to the correct location.
  5. #5
    Junior Member
    KFW's Computer Details
    Windows 7 x64
    Intel(R) Core(TM) i7 CPU 880 @ 3,07GHz
    8,00 GB
    NVIDIA Quadro 600
    Electro/Mech
    KFW's Discipline Details
    CAD / CAE ; drawing & management ; EIB/KNX
    Electro/Mech
    AutoCAD 2013
    Dec 2012
    Germany
    21
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by johnseg11 View Post
    This sounds like something is different with UCS. Set to world in both files and try again.
  7. #7
    Junior Member
    Windows 7
    Civil
    Civil
    Civil 3D 2014
    Jan 2011
    South Dennis, NJ
    14
    Ucs is set to world in drawing, all entities paste in correct location except for blocks which are thrown far out in space, if i explode block, it will paste in to correct location
  8. #8
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    It sounds like there is a definition of the block already in the drawing that has a different base point. Rename the block and see if that helps. If that does not help, post both files.
  9. #9
    Junior Member
    Windows 7
    Civil
    Civil
    Civil 3D 2014
    Jan 2011
    South Dennis, NJ
    14
    Default Attaching dwg
    Block was not defined in drawing i pasted into, i am uploading drawing i copied from. circles next to A flags, ex. A-1 are the blocks going into space. tried to upload file and got error that upload failed
  10. #10
    Forum Newbie
    AutoCAD 2014
    Jul 2016
    6
    I have had a similar issue no UCS problem, no block definition for me it seemed to be the template file (map2d.dwt , original template) for some reason on certain templates this happens .
    I tried a different template and it worked .
  1. Copy With Base Point - Paste to Original Coordinates
    By Hardney in forum Civil 3D & LDD
    Last Post: 13th Nov 2013, 08:06 am
  2. AutoCAD: Copy Paste with original coordinates doesn't work?!
    By hanshupf in forum AutoCAD Beginners' Area
    Last Post: 3rd Aug 2012, 04:14 am
  3. Blocks change during copy and paste
    By montespringer in forum AutoCAD Drawing Management & Output
    Last Post: 24th Feb 2012, 09:29 pm
  4. Invalid Error: Cannot insert blocks or copy and paste into the drawing
    By ljhignett in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 14th Oct 2011, 02:59 pm
  5. Unable to copy and paste / generate blocks
    By chris820 in forum AutoCAD Drawing Management & Output
    Last Post: 9th Sep 2010, 09:03 pm
Tags for this Thread
