Removing data features
JASTON
I've done some editing on a shapefile and now have some data sets that are null. I believe this is causing a problem when using a third party program (Mapwindow) to export to kml. Is there a way to remove these null data sets - as they are not attached to any particular feature? I've tried deleting the idx file, but that only reorganizes the data table...and I still have the null sets. Thanks.
Did you check in the features after you edited them? Try the MAPCheckinAll command. If that doesn't work there is/was a small app out there that repairs shp files. Try a goggle search and you may get some prospects.
Simply open the shapefile in Mapwindow, and:
1] LAYER,ATTRIBUTE TABLE
2] SELECTION,QUERY
3] (double click on your field) null
4] EXECUTE,INVERT IN SELECTION
5] OK,CLOSE
6] SELECTION,EXPORT SELECTED FEATURES
now you get a brand new shape without NULL records, sir.
