I can't seem to be able to change the path or xrefs nserted into a drawing like I was able to in previous versions.
Example of why I need to do thie.
Every now and then our server goes down and I need to copy a file to the workstation off of the server. But now I can't just change the path.
Am I missing something?
Thanks
Make sure to look in the "Details" section of the Reference Manager, click in the "Found At" field, and you can change the path, then press Enter.Originally Posted by warden
If you really can't stand the new interface, you can use the CLASSICXREF command. But don't get too used to is since it may vanish in future releases
