084x4larry Posted February 5, 2013 Share Posted February 5, 2013 I'm quite familiar w/this command but I have a problem right now trying to bring in an iso view profile (using solprof of my 3d model) of a pipe spool and place it in my 2d detail sheet. It looks great in the model file but when i copy clip it and bring in into my 2d file it kinda looks squished and oriented a little differently. Now I know it has to do with the UCS but how can I get them lined up so to speak? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 5, 2013 Share Posted February 5, 2013 And you tried rotating it? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 5, 2013 Share Posted February 5, 2013 Can you post the .dwg and/or some screen shots? Quote Link to comment Share on other sites More sharing options...
084x4larry Posted February 5, 2013 Author Share Posted February 5, 2013 And you tried rotating it? if u mean rotate the profile that wont help cause its squished and wont look right at any rotation and if u mean rotate my model well i have to set it at 30/60 before using solprof so i can generate a true iso to dislplay on my detail sheet... Quote Link to comment Share on other sites More sharing options...
084x4larry Posted February 5, 2013 Author Share Posted February 5, 2013 Can you post the .dwg and/or some screen shots? how can i do that? Quote Link to comment Share on other sites More sharing options...
084x4larry Posted February 5, 2013 Author Share Posted February 5, 2013 OK I attached the dwg, as u notice the iso looks squished of flattened a bit. it did not look that way in the model when i created it using the solprof command. xxxx.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 5, 2013 Share Posted February 5, 2013 I guess it is assumed the user would remain in the drawing the solid profile was created in and not copy/paste it into another drawing since the viewport it was created in originally had to be oriented for that particular view. I'm saying this because I've only used the command a handful of times and always stayed in the drawing the original 3D object was created in. I could be wrong. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 5, 2013 Share Posted February 5, 2013 I think I figured out a way to do it. Please verify that you are attempting to copy/paste your 2D block created using SolProf from the original drawing into a brand new drawing. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 5, 2013 Share Posted February 5, 2013 I've moved them plenty of times. Maybe you should give FLATSHOT a try. I cannot open your drawing since you saved it as a newer version. If I get time I'll open it with TrueView and check it out. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 5, 2013 Share Posted February 5, 2013 Can you post a drawing file just of the 3D solid model? I want to verify my results using your object and not one I created. Thanks. Quote Link to comment Share on other sites More sharing options...
084x4larry Posted February 5, 2013 Author Share Posted February 5, 2013 ok heres the model and the 2d detail sheet saved in earlier version of cad xxxx.dwg Quote Link to comment Share on other sites More sharing options...
084x4larry Posted February 5, 2013 Author Share Posted February 5, 2013 oops heres the model.. ssss.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 5, 2013 Share Posted February 5, 2013 OK...here is your 2D block. Give it a test. Saved in 2000 file format. ssss[ReMark].dwg Quote Link to comment Share on other sites More sharing options...
084x4larry Posted February 5, 2013 Author Share Posted February 5, 2013 OK...here is your 2D block. Give it a test. Saved in 2000 file format. [ATTACH]40099[/ATTACH] Wow! OK how did you do it? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 5, 2013 Share Posted February 5, 2013 Magic. I notice that you used six separate lines to draw the flange (not the weld neck itself) used on the right hand side of the spool piece but only four lines on the one on the left. Why is that? You use a lot of separate lines, no polylines, too. Just curious. Quote Link to comment Share on other sites More sharing options...
084x4larry Posted February 5, 2013 Author Share Posted February 5, 2013 i didnt draw the flange... are u going to share how you solved my ucs/slightly flattened look problem? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 5, 2013 Share Posted February 5, 2013 Yes. But first the disclaimer. I'm sure there are three people who are going to say there is a quicker / easier way to do this but that is not what I was interested in discovering. I just wanted to know if it could be done this way. I used the Change Space (CHSPACE) command to bring the geometry over into paper space. Then I copied it from there into the model space of my new drawing. Quote Link to comment Share on other sites More sharing options...
084x4larry Posted February 5, 2013 Author Share Posted February 5, 2013 Magic. I notice that you used six separate lines to draw the flange (not the weld neck itself) used on the right hand side of the spool piece but only four lines on the one on the left. Why is that? You use a lot of separate lines, no polylines, too. Just curious. the model is from my client, im the guy making detail drawings so my shop can build the individual spool pieces that the entire system is comprised of... it's a huge metering system with a price tag somewhere around 60k Quote Link to comment Share on other sites More sharing options...
084x4larry Posted February 5, 2013 Author Share Posted February 5, 2013 Yes. But first the disclaimer. I'm sure there are three people who are going to say there is a quicker / easier way to do this but that is not what I was interested in discovering. I just wanted to know if it could be done this way. I used the Change Space (CHSPACE) command to bring the geometry over into paper space. Then I copied it from there into the model space of my new drawing. ur way was plenty fast enough for me Remark and i will try it in a minute here on my next spool... im needing to show the iso so the guys know which way to orient the base plates as the slots have to be going in a certain direction... many thanks Quote Link to comment Share on other sites More sharing options...
084x4larry Posted February 5, 2013 Author Share Posted February 5, 2013 ur way was plenty fast enough for me Remark and i will try it in a minute here on my next spool... im needing to show the iso so the guys know which way to orient the base plates as the slots have to be going in a certain direction... many thanks ok Remark i tried it and it worked like a charm... Dang if your aren't magic and fooey on anyone who says different! thanks again... Quote Link to comment Share on other sites More sharing options...
