bothal08 Posted February 7, 2013 Share Posted February 7, 2013 hey guys the problem happens near the end of the installation..."error: some files could not be created. please close all applications, reboot windows and restart this installation." i closed everything and restarted PC and when i try re-install it just does the same thing. Please help Quote Link to comment Share on other sites More sharing options...
stevsmith Posted February 7, 2013 Share Posted February 7, 2013 Is it genuine software? What version is it? Quote Link to comment Share on other sites More sharing options...
the ber Posted February 8, 2013 Share Posted February 8, 2013 there are some notes for you to read in the installation dialogues, iirc. you need to have administrator rights, you might have to disable your anti-virus software, you might have to install newer versions of .NET, etc. etc. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 8, 2013 Share Posted February 8, 2013 Might look into CCLEANER if that doesn't work ... Try the Microsoft FIX IT tool. Quote Link to comment Share on other sites More sharing options...
bothal08 Posted February 8, 2013 Author Share Posted February 8, 2013 yes it is genuine...i downloaded it from autodesk Ive just used ccleaner and now im gonna try install again...if that doesnt work ill try microsoft fix it but ill get back to u guys thanks for the help so far Quote Link to comment Share on other sites More sharing options...
bothal08 Posted February 8, 2013 Author Share Posted February 8, 2013 ok so Ive tried microsoft fixit and ccleaner and it still says the same thing that i mentioned in post one...it happens right at the end of the install...in the install log which flicks through topics it says "x64" when the error occurs...dnt knw if that helps and its the 2011 pro version Quote Link to comment Share on other sites More sharing options...
Cad64 Posted February 8, 2013 Share Posted February 8, 2013 In order to help you with issues like this, it is important for us to know your full computer specs, (processor, ram, video card), what operating system you're running, (32 bit or 64 bit), and what Autocad version you downloaded, (32 bit or 64 bit). Also, are you installing Autocad or Inventor? Or both? The title of this thread is a little misleading. Quote Link to comment Share on other sites More sharing options...
bothal08 Posted February 9, 2013 Author Share Posted February 9, 2013 AutoCAD inventor suite 2011 64bit specs i3 @3.3GHz windows 7 home basic 64bit 8GB RAM DDR3 NVIDIA GeForce GT 630 Quote Link to comment Share on other sites More sharing options...
bothal08 Posted February 9, 2013 Author Share Posted February 9, 2013 problem solved all is good...thanks guys Quote Link to comment Share on other sites More sharing options...
the ber Posted February 9, 2013 Share Posted February 9, 2013 Can you let us know what the solution was? Somebody else may run into the same problem and find this thread. Quote Link to comment Share on other sites More sharing options...
