eyde Posted February 12, 2013 Share Posted February 12, 2013 I am writing a script to redefine the title block but am having some trouble with it. The main problem is that when I wblock the new title block and use the block option Instead of picking the block itself there is no block in the new drawing. If I wblock the title block itself then this is what I get Command: -INSERT Enter block name or [?]: "catalog web border=F:\Engineering\BORDERS\catalog web border.dwg" Block "catalog web border" already exists. Redefine it? [Yes/No] : y Block catalog web border references itself Quote Link to comment Share on other sites More sharing options...
dbroada Posted February 12, 2013 Share Posted February 12, 2013 that is because you have a block called Block catalog web border within the drawing file Block catalog web border.dwg I am getting confused by your use of WBLOCK. This is the way to write blocks to a file and nothing to do with inserting a file. If I have to redefine a block I use the INSERT= method. This will allow the redefine from an external file. I also insert the new border (so now I have the original border but redefined) plus a new instance of it. I then ERASE L(ast). I find this easier than escaping out of a script. Quote Link to comment Share on other sites More sharing options...
eyde Posted February 12, 2013 Author Share Posted February 12, 2013 Thanks I will tryout your suggestion. Quote Link to comment Share on other sites More sharing options...
eyde Posted February 12, 2013 Author Share Posted February 12, 2013 Well I finally found out what was wrong. The wblock that I thought did not have a block in it actually has the definition in it. So I was able to write the script with no problem. What I did was open my new border.dwg and went into the block editor and wrote the block to a file. This exploded the block and just kept the definition. blockreplace.scr Quote Link to comment Share on other sites More sharing options...
dbroada Posted February 12, 2013 Share Posted February 12, 2013 that's pretty much what I was trying to say. Quote Link to comment Share on other sites More sharing options...
